Home Arcade System
Swap? I'm pretty sure its 220 for safety man, that's a shit load of outlets.
I'm just using it for low power odds and ends. My PVM has its own dedicated Line-R 1200R, as does my PC, and those will be on separate outlets. I'm not going to be pushing this thing to 100w probably--I just bought it because it was $35/shipped on eBay and it was the perfect length for the desk.
When did you pre-order? Confirmation was sent only to people who managed to get on the batch 1 list.
Home Arcade System - new supergun sets
I was referring to the new preorder link you put up recently, I didn’t get an email unless that google form just listed me down or something.
Edit:
I just got my OSSC in today, and I was wondering if I should order one of these cables.
https://retro-access.com/products/n...-stereo-rgb-scart-lead-for-rgb-upgrade-boards
Since I have an OSSC now, everything that isn’t HDMI native will go through that.
I got the recommendation from this guy’s HAS video.
Like for example, right now I’m running my Saturn through the OSSC via RGB Scart.
There we go :D
what's capture card used please?
Is that the confirmation email from Jun 15th, that we had to reply yes or no?
sir,try it and see what Mike will reply you on your email...or maybe your turn has gone since you didn't give any sign from 1 month ago since today.
Oh, that's not the issue. I replied immediately lol. Just wanted to make sure I was on the same page with what I've read in the thread since the email was sent.
Yes, it's the one from June.
Awesome! Thanks for the peace of mind.
Does anybody know if any of the recommended power supplies are available in the USA?
The FAQ lists the following:
– Mean Well MWP-606
– Prima Power 42PP0606 (can be bought directly from SUZO HAPP, at least in Europe)
– Mean Well RT-65A (only 65W, so double check if it’s enough for your games)
I'm a completely newbie regarding arcade PCBs and SuperGuns.
I've pre-ordered the new HAS and also a Neo Geo MV-1C. My goal is connect the MV-1C to the HAS and also my MAME cabinet (I think a custom controls -> Jamma female adapter?).
Anyways, I'd also like to purchase other arcade PCBs (CPS2, TMNT, etc).
Can somebody recommend a good PSU that will be compatible with everything I'd want?
Also, are there any guides to purchasing arcade PCBs and what adapters I might need for the HAS? (i.e. what a kick harness is, why I might need it, etc, etc.)
@sofakng this psu works fine with everything you mentioned: https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/123679840929
You’ll need a power cord and if you’re new I’d say just buy one. This probably fits. Worse case you don’t need the spade connectors and you can run the wire directly, but this is nicer.
https://www.parts-express.com/ac-po...tors-18-awg-3c-sjtow-300v-black-6-ft--110-101
Buy the HAS cps1 and cps2 kick connectors, that’s most games. JNX makes a “raiden” adapter you can buy, and that does a good job of converting to a couple other formats, and he can make harnesses too. JNX Raiden - CPS1/CPS2 to Mortal Kombat Adapter
For anything specific you can usually google for an arcade manual and you’ll have to look at pinouts. Or just put “[game name] kick harness” into eBay. Most games don’t need one unless they are fighters or use 3 or 4 players.
Many games are jamma so plug/play with the HAS. Older ones can be converted to jamma, with an adapter board, but it’s easy to just google search for it usually. Don’t buy any of these until you own the game though. Newer games could run on JVS (Sega Naomi and later) and can work with a HAS but just do some research on that when you get your bearings with everything else.
As for buying pcbs, eBay and KLOV are a good place to start. Just search what you want and look at sold listings before buying anything, to get a feel for what the real sale prices are these days.
@RGB can we still update our preorders (the new recent ones)? I’m considering future proofing myself by going for more Capcom kickharnesses and your 3P/4P adapter.
I was able to get in the order for Undamned’s USB encoders, so providing I can also get 2 of your Saturn adapters (my HSS-0130 really needs to be used on a Supergun in addition to the Saturn), I would be able to maximize my options. :)
Thanks so much for all of the information! I've order the PSU and will do some research on everything else that you mentioned.
Does the PSU connect to the HAS and then the HAS provides power to the MVS? (over JAMMA?)
The power cord has green (earth/ground) black and white (AC) which connect to the psu. The psu connects to the HAS with a harness RGB sends with the unit. Then yes the HAS sends power to the board via jamma. Look up the jamma pinout and you’ll see which pins are for which voltage.
The PSU is adjustable as well, and your HAS has a voltmeter on it. Just make sure the meter reads a bit over 5v, like 5.05 when everything is plugged in - HAS and pcb.
Certain boards draw more or less power so you’ll adjust the knob on the psu to raise or lower it. The knob moves backwards to what you’re expecting btw.
Thanks so much everybody.
It looks like my MVS MV-1C will arrive this week so all I need now is the HAS.
Next I need to find out how controller input works. (real arcade controls, and perhaps USB devices? I think I saw something called Undamned USB decoder?)
Anyways, I'll do some searching and see what I can find. I don't expect to be spoon-fed everything :)
If I have any questions I'll post back though. Thanks so much!
@RGB I already have a previous version and am super happy with it. Can I be added to the list for another one.
I'm getting some interference with the tim's nesrgb cable (Diagonal lines) on the mini din. No such interference exists when i use the 15 pin dsub connector which rules out a power supply issue. This is possibly because the mini din cable is not of good quality.
I'm thinking about getting one of the following:-
https://retro-access.com/collections/other/products/8-pin-male-mini-din-to-male-rgb-scart
https://retro-access.com/collection...-stereo-rgb-scart-lead-for-rgb-upgrade-boards
https://www.retrogamingcables.co.uk...-CDi-Colecovision-Intellivision-Panasonic-3DO
Does anyone have any feedback on any of the cables above? Preference?
Thanks
