Home Arcade System
EDIT - I found a different thread here saying the HAS may be available in Feb on a webshop, so I will look out for that. But I'll leave my old mssg here in case anyone can help regarding the other stuff.
Check this
What shop is the the HAS available from?? Do we have any exact date? I am impatient AF right now. Thank you.
Check this
in any rate...for sure a new batch will be available on the shop directly...i don't think will be another pre-order call.
You’re in the shop right now, broskii.
You know, that would be a cool name for a beer.
Give me a Broskii Brewskii.
You probably wouldn't be able to say it after you had a couple...
:D
The slogan could be "Come at me, brew!".
Or "don't taze me, brew!!"...
Or, "brews, before hoes"...
The possibilities are endless.
Hi, I'm new here. I'd like a SuperGun and I keep getting recommended this one, but I'm given two links, one is this forum and the other is shmups.system11.org . I registered there and can access it, but not the thread where I've been told I can buy a HAS from, it tells me I don't have permission.
So I came here. Just to confirm, they are no longer for sale and can't be pre-ordered, is that correct? That's what it looks like from the link on page 1. Sorry I know it's probably an obvious answer, it's just I want to make sure because I keep getting told to buy a HAS really recently, as if they're available, but it looks like they haven't been for ages.
I actually just want one to test a Mortal Kombat II board, I've had it for decades, never used it and never used a SuperGun before. Just want test it and then most likely sell it as well as the SuperGun, unless I fall in love. Everyone keeps telling me other SuperGuns are bad and dangerous or something. I'd like the full package so I don't have to put stuff together, as well as a power supply. I know quite a lot about games tech but original arcade hardware is a weak spot for me, and power supplies in general is another. I don't mind losing a bit of cash when re-selling the SuperGun, though I'd like it if I didn't lose a lot, as it'll be barely used. I don't know what the after market for these kinda things are.
So any help would be great! Umm, maybe someone could lend me one? I doubt that would happen though as you'd have to trust me, haha. Thank you for your time.
So, the HAS is one of the best and safest SGs to use for sure, BUT, MK2 is an odd board and if you are trying to use it with a CRT TV, it will likely have roll and not be useable for gaming. Honestly, for that one game, why waste the time and money getting a SG to work, just use MAME or one of the countless ports of it and be done. Don't forget, not only will you have to buy a PSU, but also controllers for MK2, which also needs a kick harness... lots of cost just to test a PCB. Why not just sell it untested?
Like I mentioned, I don't want to get it working to play it, so I'm not interested in playing it in MAME or any other port. I would like to test it and then sell it.
It’s up to you and I don’t want to sound like I’m just criticizing. But buying a supergun just to test your MKII pcb so that you can just sell it afterward is a waste. Like it was mentioned before, you could just sell the board untested so your buyer will know buying before hand.
That sounds pretty odd whoever told you superguns were bad, the only ever caveat I knew of superguns in general were for their price, not for some other reason. The only questionable superguns are probably those CHAMMAs sold on aliexpress or whatever.
Like it was mentioned before? You're the second person to reply to me, the first said I should play the game in MAME. Sorry unless I missed something. Selling a board untested is almost the same as selling something as faulty, as I cannot guarantee to the buyer that it works. So I would get a lot less for it, most likely less than half.
Check this
Check this
Thank you.
People are trying to tell you, your plan doesn't make economic sense. You will pay a lot more for the HAS supergun, power supply, controller adapter, kick harness, and RGB cable then you will get from selling a working Mortal Kombat II PCB. And that assumes you have an analog RGB compatible display. If not, then add on the cost of a video converter of some sort.
I don't need to buy a controller adaptor and analogue RGB compatible display. I'd like to test the game anyway. Do you know if the HAS SuperGun comes with a power supply? If it doesn't, could you possibly recommend one which is available to the UK and works on UK power? No worries if not.
Would you guys give this guy a break. His eyes are obviously on the big pay day of selling a working MK 2 board. How much do they go for these days $300- $400 US?
Serious though Brendle if you're starting from scratch on getting that board to function. You're better off finding someone in your area to test it for you that already own the gear to verify that it works. You can always send it my way. I can test it for you as I got everything to verify if it works.
LoL
Mortal Kombat II is a JAMMA standard board, meaning you can test it in any arcade cab that has the JAMMA standard wiring.
I would try to find someone local and see if they will let you test it.
:D
Clearly you don't want to take the advice of everyone here, but once again I'll state that even if you bought a HAS, the PSU to go with it, joystick (to test functionality), a kick harness, and then plugged it up to your TV, you could STILL have issues with it syncing to your TV, so you couldn't be 100% sure the PCB worked properly. Now you'd have to invest in a scaler or line doubler like the OSSC, then get the correct cables for that, THEN you could test on a modern TV, then you could sell everything for a loss, just to test a $250 USD game?
I can save you money.
Step 1: Mail me your PCB to the US at your cost.
Step 2: I will test your PCB for you for free.
Step 3: Regardless of if your PCB is working or not, I will keep your PCB and give you nothing.
Step 4: You have now saved money and time. You're welcome.
@xtrasmiley recommended MAME or other ports, and was the first person to suggest to not buy a supergun for the sole reason to test a board for selling. I just agreed with that notion, but I didn’t recommend emulation or ports.
LoL
Thank you zionfarm, I'll look around in my area! I'll think about sending it to you too, you're probably pretty far away though, haha. I'm in the UK. Also I would like to say to everyone that I WOULD like to get a HAS and keep it, I'd love to get some game boards but I'm bit broke right now. But I'll see what I can do. I used to have a stand up ElectroCoin Neo-Geo cab with 6-Slot MVS ages ago, but this guy I thought was my friend stole it from me. That cab was my pride and joy. Sad times.
Cheers, I'll look around. I don't think there is any in my area though.
@xtrasmiley, it's not letting me quote messages all of a sudden so I'll just reply manually - Thanks for you sage advice. I'll pass though, I'll try to get a HAS instead, as I'd like to learn about arcade hardware. Though they seem to be in high demand so I might not be lucky.
@lupinko said: "xtrasmiley recommended MAME or other ports, and was the first person to suggest to not buy a supergun for the sole reason to test a board for selling. I just agreed with that notion, but I didn’t recommend emulation or ports."
Apologies, my bad.
How about power supplies, would this one be good for a HAP? What would you lot recommend ? -
https://www.ebay.co.uk/itm/16A-Arca...588698?hash=item593f917d1a:g:9CkAAOSwcqFd9IEx
That PSU will work, but it's very low quality. For MK2 probably not a big deal, but for the same price (or just a tad more) you could get a much better PSU such as a Mean Well brand.
Most at this point recommend avoiding Chinese PSUs and even Happ ones as the quality has gone down dramatically.
Stick with the same form factor, but a Mean Well branded one.
Seriously though, you guys really trying to talk people out of RGB making a sale, in his own sales thread?
If the guy wants to buy a HAS, let him buy a HAS.
RGB would surely appreciate another customer, and we can all suffer less posts of you guys telling people what they should do with their money.
This forum isn't about ripping people off or making them waste money unnecessarily, even at the profit of one of our own. It's about helping people and creating cool products.
If his best course of action is to sell his board untested, that's what we will advise him to do. If the best course of action is to buy a HAS (which now it seems he wants to do), then we will help him do so and advise on best parts to buy, such as PSU.
I've sent at least 6 people toward a HAS based on how awesome it is. Despite my love for the HAS, I would never talk someone into one that doesn't need it just to ring up a sale. That's pretty shitty.
Most at this point recommend avoiding Chinese PSUs and even Happ ones as the quality has gone down dramatically. Stick with the same form factor, but a Mean Well branded one.
Oh sweet, Mean Well? OK I'll look that up, cheers. Also concerning earlier posts, I get what you mean, I'll make an effort not to actually lose money.
If the guy wants to buy a HAS, let him buy a HAS. RGB would surely appreciate another customer, and we can all suffer less posts of you guys telling people what they should do with their money.
Haha, nice gif. Thanks for the support. It's cool man, I must have come across badly at first. I'm guessing I shouldn't have heartlessly said I'm gonna just sell everything, probably comes across as uncaring or disrespectful or something. Also I should have done a thorough check first to see if this thread is actually for beginners, because I don't wanna bug ppl with my noob questions if it's not. I'm gonna see if I can sell some of my stuff so I can afford a HAS and maybe skip some meals, haha.
^ This. Of course I want to sell the HAS, but not at all costs. In this case my recommendation would be to start a fresh thread and to look for somebody in the UK who could test the board for you, you will save money and time (because I don't have any spare HAS units at the moment).
@St4rwalker - just for reference, a brand new HAS V3.1-V4.0 cost €122. V3.1 is almost the same as the V3.2, except it doesn't allow to disable button 4 on the JAMMA connector. It's not a big deal unless you play Vampire Saviour (button 4 on the JAMMA edge causes an error with some special move in this game, I can't recall which character and move exactly).
I've got some bad news - next week I'll undergo a minor operation and this will affect the delivery of the next HAS batch, I won't be able to work for good 3 weeks (however I think I might be able to continue shipping the pre-orders) :(
Good news is that I should finally have the JAMMA extension harnesses ready in the first week of February.
Just dedicate yourself to getting better. I'm sending maximum karma your way.
Who said anything about ripping people off?
What I'm saying is that he mentioned MULTIPLE times that he wants to have a HAS. Why beat a dead horse if his heart is set on owning one?
He also mentioned that he wants to eventually own more PCB's...so why try to run him off (which is what you guys seem like you're intending). We want people to join this community, grow this community, not be cock-blocked by existing members of this community.
I don't get how you're implying that I want him or anyone in the community to get ripped off.
Your snarky response of a "plan" to keep his goods is more of an indication that you would rip him off, rather than allowing him to purchase something he desires. How is that "helping people" huh? :thumbdown:
That's fine man, its your property, and your money. You do what you want with it. The HAS is a great piece of tech, and even if you don't have multiple PCB's now, you probably will in the future. It looks like you're just starting out, and you are interested in getting into this hobby more. You are more than welcome here! Just take people's advice with a grain of salt, and in the end make your own judgement on what's the best course of action for you.
If you do eventually get a HAS, might I suggest one small thing: thoroughly read the instruction manual before asking questions. :D There have been a few instances where folks didn't know a feature or an operation exists, on this product or others featured here, but they were outlined in the manuals. Best to read through them first and see if you can find your info there (they're really well put-together), then ask questions to the forum if you can't find your answer.
