dos
Is there any way to get notified then pre-orders are available? Is the only way to keep checking the website?
Thanks roy,i think it will better if you guys send him a pm.
just saying...
I've never had a PCB not have sound with the HAS. Can you list some titles and maybe we can figure it out.Hey. I'm double testing a couple bootleg boards on the HAS that werent working in my NAC.
For some reason. I cannot get sound to work on the HAS.
I have it connected through Mini Din to SCART and my other scart consoles sounds are working great the Banbridge auto switch.
I even hooked up an headphone to RCA adapter I cannot get sound to come through.
I feel like I'm missing a basic step here...
Edit: I used a PCB that had working sound on my NAC but didnt work on HAS. But when I plugged in the M-72 Multi. The sound was working.
I wonder what makes certain PCB's have sound on cabs but not HAS..
I’m happy to. Tomorrow it goes downI've never had a PCB not have sound with the HAS. Can you list some titles and maybe we can figure it out.Hey. I'm double testing a couple bootleg boards on the HAS that werent working in my NAC.
in case of some bootlegs, you are right ... no sounds ... Mike will teach you what to try to have sounds on some of the bootleg pcbs !Hey. I'm double testing a couple bootleg boards on the HAS that werent working in my NAC.
It may be the sync as some games will not work properly with a PVM. Have you tried changing the sync settings on the HAS?Hello, I noticed that some boards (original and bootlegs) displays and image problem with the HAS that is not present If I connect directly on an arcade cabinet.
The image is distorted diagonally and the "NO SYNC" text is displayed on my PVM (SONY 20M2MD). In most cases also the sound is crippled and unrecognizable.
I see this issue on many boards. For example: a Neo Geo MVS mv-1fz works perfectly fine but both the Galeco boards World Rally 2 do not (but the WR1 is working).
My PSU is a Meanwell 606 and I checked the voltage supply of it (with a multimeter) and it seem fine (+5v, -5v and +12v).
Any one has any hint for me?
Thanks in advance
Don't sweat testing different CSync on a HAS. RGB designed it to avoid damaging your PVM, however, this advice does NOT apply to any other SuperGun unless the creator can verify it.Hi XtraSmiley, thank you. I will try to play with CSync SW2 switch (and as a last resort with the SW3 switch).
I noticed the two switches and I read the manual about them but I was afraid to mess with something and damaging my beloved PWM.
Thank you again.
This PCB is Konami Classic pinout. Get this adapter from Arcadeshop.com and you can play lots of boards with it!Also I'm considering getting a Green Beret (Rush'n Attack) PCB, but from what I understand, it doesn't use JAMMA. Is there a recommended Jamma adapter I should use? Much appreciated for your help!
Yes sir ... about the adapter i've used with my Rush'n Attack pcb is not available for i don't know what reason ... but you can get this sir : https://www.arcadeshop.com/i/363/konami-stern-series-jamma-adapter.htmI have a HAS 4.0 2019. I heard something about a 4.1 version coming out. Can anyone tell me what the new features are? Also I'm considering getting a Green Beret (Rush'n Attack) PCB, but from what I understand, it doesn't use JAMMA. Is there a recommended Jamma adapter I should use? Much appreciated for your help!
Too slow!Yes sir ... about the adapter i've used with my Rush'n Attack pcb is not available for i don't know what reason ... but you can get this sir : https://www.arcadeshop.com/i/363/konami-stern-series-jamma-adapter.htm
