sammargh
Undamned referred me to here when I inquired about decent superguns and the sync features have sold me. I too would be interested in a HAS with 2 Saturn adapters and cps1/2 kick harnesses if they are available. Thanks!
Interestingly, the EU SuzoHapp link for the same power supply that has been shared in this thread no longer works.I'm in for a second supergun as I'm extremely happy with the first HAS supergun. Your product is top notch. Just one thing that I am running only CPS3 and Neogeo board, it would be nice to have those laptop powersupply as an option so that I don't have to use a proper arcade PSU which looks like some frankeinstein setup on my desk. It would be also super easy for me to bring my board around for tournament use. Also would you consider integrated Marq's CPS2 AV into next version of HAS?Guys, thank you for interest. All units are on hold. I plan a smaller run (~10 units) in around 2 months.
If you find a suitable PSU (at least 4A on the +5V line and 1.5-2A on the +12V) then I can help you with adapting the plug so that it can be connected to HAS, or build an adapter.Just one thing that I am running only CPS3 and Neogeo board, it would be nice to have those laptop powersupply as an option so that I don't have to use a proper arcade PSU which looks like some frankeinstein setup on my desk. It would be also super easy for me to bring my board around for tournament use.
The CPS2 digital AV interface is installed in the actual CPS2 A board, not in the supergun.Also would you consider integrated Marq's CPS2 AV into next version of HAS?
I got the cable as you suggested from Retro Access today. Upon hooking up to HAS Supergun and Scart side to my B&O MX7000, nothing shows up. Just black screen. I've thought it might be my CPS3 acting up, then I try to hook up to my Neogeo MVS board ---> same result, black screen. You guys can check video herethe cables are handmade and she opens up stock every morning at 7am. Once enough cables are sold, they all show "out of stock" until the next day. I also think she might have taken a vacation over the holiday. Just check back, they're great cables.It looks like they ran out of stock for the cable... I've searched around but it seems there is no other store selling this cable as wellThis SCART cable works great with the HAS:https://retro-access.com/collection...-stereo-rgb-scart-lead-for-rgb-upgrade-boards@RGB
I just bought a Bang & Olufsen CRT tv with Scart. Do you happen to sell any Scart cable for HAS supergun?
On my B&O MX7000, only first AV1 Scart port seems to work. The second AV2 Scart port does not allow me to display any picture at all. Also on my tv, it has dedicated S-Video DIN port.Edit: I've just watched the video. Did you try to connect the Scart cable to the other TV Scart socket? Very often only one socket accepts RGB+Sync, the other socket takes composite video/s-video.
Thanks I have the exact cable for my BVM.Then get this or this.
The one I linked above is the wire I use with my HAS V3.1 and PVMs; I also have two of those breakout cables and they work fine.
Strange as that's the exact cable that I ordered but this cable not working for me at allI got this one and it works fine: Multicore Coax version
The problem is that a few 6 button CPS2 games (Vampire Savior is definitely one, but scant rumors of 1 or 2 others) are still sampling 4 JAMMA buttons instead of only the first 3 for punches. If the supergun has Kick 1 from the kick harness wired up to JAMMA button 4, a command super in VSav will be canceled when the game sees activity on JAMMA button 4.Not sure what's the issue with Vampire Saviour, but UD-USB is compatible with HAS.
