The RGC PS cables have a LM1881 in them, and I'm pretty sure they add a 470R in series on the sync output.
Thats good, I didn't see it in the instructions, and many Super Guns do not. Another reason the HAS is the best!Of course HAS supports -5V![]()
Need to verify that your power supply is capable of outputting it.
Yes, you do require a power supply that is able to generate -5v for those games, since the HAS has no negatron inside.Thats good, I didn't see it in the instructions, and many Super Guns do not. Another reason the HAS is the best!Of course HAS supports -5V![]()
That being said, I have the HAPP arcade PS I linked in my thread, which only puts 5/12 to the HAS. Do I need a PS that will generate -5v? Not important for this game above, as the sound is another problem, but for future games...
OK, I guess that is what I'm asking. So I just unscrewed my wires to look and I see that the green wire is -5v, ah-ha! Even in the RGB instructions pictures, I couldn't see that! LOL, more info for the FAQ!Yes, you do require a power supply that is able to generate -5v for those games, since the HAS has no negatron inside.Thats good, I didn't see it in the instructions, and many Super Guns do not. Another reason the HAS is the best!That being said, I have the HAPP arcade PS I linked in my thread, which only puts 5/12 to the HAS. Do I need a PS that will generate -5v? Not important for this game above, as the sound is another problem, but for future games...Of course HAS supports -5V![]()
Sadly I don't yet as I don't fully understand it and don't want to blow anything up (speakers or otherwise), but as you guys explain it out, I'll add it to the running FAQ. Maybe soon it will be big enough to have its own thread.how do you guys deal with boards that output stereo?
Like Konami, 1slot MVS etc.
Do you run a separate high/low converter to get to RCA?
Or could I use one of the additional header on the HAS to feed stereo to it and output via the RCA plug?
That would really tidy up the setup![]()
1slot MVS all are mono (at least at the JAMMA end). The stereo ones are 2-4 and 6-slots. For those, I have a JAMMA extension (bought to RGB along with my HAS, IIRC) which has some jumpers to change it from JAMMA to MVS audio setup.how do you guys deal with boards that output stereo?
Some 1slots have a 4pin JST NH header for amplified stereo1slot MVS all are mono (at least at the JAMMA end). The stereo ones are 2-4 and 6-slots. For those, I have a JAMMA extension (bought to RGB along with my HAS, IIRC) which has some jumpers to change it from JAMMA to MVS audio setup.how do you guys deal with boards that output stereo?
Don't for get the speaker-level stereo from the Taito F3 as well.yeah would be cool if the HAS had a 4pin stereo input header where I can feed the amplified stereo out from my boards, and let the HAS attenuate to line level for the RCA plugs.
Would that be an option @RGB?
Boards I want to run with it:
- Konami stuff, Simpsons, Xmen, Turtles etc.
- NeoGeo MVS 1 slot
- Atomiswave
CPS2 already has RCA line level out, so that's all good as it is![]()
#MeTooMy 1 slot has stereo from jamma.
The 1F and 1FS motherboards give both stereo and mono output over jamma selectable via a switch on the board.whut? 1slot with Stereo from Jamma?
Does that have similar Jamma pinout to multislots then?
