I got it all up and running last night. I couldn't be happier!
Cj88yugh_WV1CJ-MS54i3dRQ9eiI20xmW3pbpn-0QLnWUT3tIopG3wAlRQCSy0onFLerxPxzTCvAl8sj7NP5ZwhwA-ZJ5JsSimhprR6S9pibDLfy92LaYEjAswhJUC3TEdPIVuX8G52Sljz6mPXODCbWZ7L4Y26TYBIplnsfl7CVnwLCq8AeQ8LYVx1K5oF11E8tRqJAC34OcymX1IfOzpIqgYnRKK5_V19Fhaq4mg1YidZGdPJKKdo9zMAkH1JW766UjXb_HGyrMIJ_SPnP-07fx7REadZRWbGp3FCP1uLhFU6Ty5cjf5g6m-itDKUI95YLz0-Fp9bNazgJfe5TrzT8EoPK5BMajyKxdzmNqRDYSso07a1QIfOgxij5AyKZxa7N87sEiSjXSCTvdbK_DV0oPF79-BYdowehtqGygCR_kDOCjXXg1PTy9DiHkhXFCFW3Ch9LfiJYlSnzXEwqR18MZ972Hijp90XpaWuYiwXROCY4dFGhzeO3H7YhqOGoifn4q1bAcgjSC-ZKeAqwRMfk2tKj0XvYwl9NRgBd-b2psnaMLjidGsFnRfPL-rHPMqdmQFajc-nG7ZhtVfnA6nm22JxHbOHjH1Vi0QOPGRDW8IJTlbeJIvgRZjyvaInfeZO1-AUgUYCTdQBXlLzzdgME=w472-h629-no
RyMMKFzRzfSaE8h2dRQ0IqdhNvJcJF7HApXMPV_Cq1I94fcsJBMTfFAsuksFkmGvdXJZKAamePnviVmeqOEq2vhmNGuh5Z7JR3sa9YkgRWwUL59DNOxCQYk4sU3AcqvEFcgpVS5tgM18EcsBJufYuOURQJnHRQKTpUlNxuopNMbIXq9M-eA5Po12xFmMfH_ZIqYzcZAJIMlBE1p18rCtBCC-GYEGmyRKqnQD8ZxDa3JW8lr-f9RL6DBTzQtQx7iW0ItoAuTrhbZPpcWuFrrpJsxUBicP51Gttv02_Dn3Eeh-k_RzgjkQ2503R6VGpgxxvb0w7qKL3A9fhuFF5PNPfvq9ypPUuccWyPMhgskbMAix0ACTFnU561ZSgd5ixix6PQvWgFFkJfvxJ-9jzR2iXfPOmAK_8Bgm31ViXCBL3fA1ep2pWzDLI9CnHmOk4YMXWLbpxqjTG168-wgSWp4O1sXTVDv1wWVi_YF5oFBxpC4Kh01QnbJSAHJY8_Y1QTsoc3WMe4XhBprKSaxR9Rlf2qdnDQrxENTmJs-OAVxY331FpZE4KqhrYLQiaYqZTYvu3njihdPMCSayqde7t0rV_Qkm7H9omRdVx_WxXpy-Xc5_WCYsmucFX3K5VWK5eAAHwvdz0oM6Q8n_Hmra5dDa2d8h=w839-h629-no
igRgiQ9CvK4odS47k7kzqeYYSI4Q3EKnj2wQR6_-M64IqqpjsPtQa34M3idgzXqtT85GYRccx9sF1b_xEXQSg5LvL9Bx5tlriizmsZwpPeDPY7QC7vDz9fTrhL_y4yX0AWExfTh4Noxf3sWS-K-Bzcs5HDZaznOoaTGrHBdJhktLR5aBtvugGPgwmWwRSFmdO_fGzQAIQG3TC7OpvRQQC1fpi3yOBBGSAg2szazTzlf_f7VYmt6OAyQfpE8PCiMKtOfGZbEH_TVx0IG7KF6Uekc4x-kdN1KUuu-gQmRQGrfsk9lueHN3TykDrtZAHKiVkUTVC3bXj7NxuvEI5nZM33yl5tXso9Jv68C4xkIEB-qrcwyT0Ay3q2Kt-dxfxApg8MaqoVqVREyFk__8lMlsx_74g8J0xyUHWGztayyMoDpySoWPfY8OqPNktke09CzGyWgUDFYB6mCUSgdXEHhUYyTDUJ-WVNGekbm1bKt_REWXikD1yXbpZOeI9Vx8mYqQJ63oKHX3hmkoRv66sNxswZhd_ND4jAL_zG5bAEOccvHC0xPhncU2kSlziE48MLmoAo5b93dQyfKdDN1Z3YdK4WmDZR2LqeMB-v1FrMLZ6_R4G0yW9ATG0Sgjfd969bAyl5-pSciGFb7Iq0_KX0zM_IiG=w839-h629-no
This looks pretty amazing!
Thanks! You made it possible! Now I just need to figure out what I want to do for a controller for fighters. Quick question, do I need the CPS2 4 player harness seperate from the 4-player add on board for the HAS to get a third player working? Right now I have the 4 player expansion board but I don't have a cps2 or konami kick harness. Just curious about what those are specifically for.
Yes, you'll need a 3/4 player harness for the 3P4P adapter for the HAS. The adapter is just a PCB with two controller ports and a 34pin connector. The 3/4 player harness will plug in to the 34pin connector on the 3P4P adapter and the CPS2 (the same connector you use for the kick harness).
Finally got around to testing the HAS. Thanks @RGB for building this beautiful piece of hardware that allows us to play arcade games at home. I tested a CPS1 board that i have and it worked perfect out of the box.
I'm also looking at getting a pacman and a nintendo vs board and wondering if anyone has tried those out and have suggestions for a suitable midway pcb to jamma adapter and a nintendo vs board to jamma adapter that they could recommend for use with the HAS Supergun.
I found the following pacman pcb to jamma adapters:-
https://riddledtv.com/arcade/jamma_adapters.html#PacPcbToJamma
https://www.mikesarcade.com/cgi-bin/store.pl?sku=PAC2JAMMA
http://www.arcadeshop.com/i/369/pac-man-series-jamma-adapter.htm
For nintendo vs, i found https://www.mikesarcade.com/cgi-bin/store.pl?sku=VS2JAMMA
Any feedback from anyone who may have used any of the above adapters with the HAS would be very appreciated.
Eventually, I want to get https://riddledtv.com/arcade/jamma_switchers.html#6way so that i can keep all the pcb's that I acquire plugged in and be able to switch to the one that i want to play.
I'm waiting for Jamma Extension sets with HAS kick harness support[.7832/url] and hope i can obtain more for use with the HAS and the Jamma Switcher.
Reactions: RGB
While I can't speak about the specific adapters, I can say...
Order with 100% confidence from all of these vendors. Top notch! I have placed orders with them for a long time.
If you have a problem with your order, they will take care of it.
Jim, Mike, and Steve have helped the arcade community for a long time.
All great guys.
:thumbsup:
All great guys.
:thumbsup:
@brentradioThanks so much for validating the resources. As i am new to the arcade stuff, this is really helpful.
Finally set-up my HAS on a 14" PVM (14N6U) at my desk for vertical games.
Currently connected to a Namco 20th Anniversary Ms.Pacman + Galaga board. Thank you @RGB for such an awesome device!
That's a lovely setup, it's a pleasure to see one of my JAMMA harnesses from ~2016 in the wild :D
Are you referring to that JAMMA extension cable? Are they still available? It looks high quality.
Yeah, RGB's extender is fantastic. I had to opt for it when they were available.
I also like to use a JAMMA right-angle connector with my HAS. I bought it from shadows on the N-G forums, and it helps with space and organization (originally it was supposed to be for my arcade cabinet and bigger PCB's that barely fit in the PCB bay).
Here's an updated shot of my set-up, with shadow's right-angle connector, RGB's extender, 3P4P and HD-15 add-on board.
I love my HAS!
Liking the right angle connector. Might have grab one but best tread carefully, there a playful bunch over at N-G forums ;)
Hi RBG, finally set up and the device is fantastic. Everything is perfect.
I have on slight issue, can someone help me why i have this gap?
yeah something seems off there.
