I still can't find an answer to this, could someone with a an 8 pin mini DIN cable please pop open the scart housing and check if a resistor is present between pins 8 and 16?In regards to the 8 pin mini DIN cable, how are they wired on the scart end in terms of the switching and blanking pins, pins 8 and 16 respectively? Specifically, is the usual 180R from pin 8 to 16 present, to lower the voltage to correct standards?
Just wondering as I've not seen information on how the official XRGB or third party cables are wired in this regard. I've always been told these cables contain no passive components, which is part of their appeal, but if they're omitting this resistor than they're delivering a voltage to RGB scart TVs that is out of spec.
I have discovered that the XRGB mini adapter cables, whether the stock Japan 21 cable included with the device or an aftermarket one wired for Euro scart, DO NOT contain the resistor. Which makes sense for its intended purpose as an input into the XRGB mini, but is potentially a problem for using it as an output cable. Likewise, the kit you can purchase from Tim Worthington that uses a PCB to convert a scart housing with a mini DIN connector DOES NOT include a resistor to lower the 5V output.
It seems to me this may be a huge oversight and a potential cause of concern. Not an issue for OSSC or PVM/BVM usage but certainly should be investigated in regards to scart switches and CRT TVs.
