Home Arcade System
does anyone know which (month's) orders are currently processed ? I placed order I think in June, does anyone know how long i should be waiting to get the payment request ?
@jassin000 - the new HAS uses a different type of JAMMA connector, so this has to be confirmed first before suggesting to buy JAMMA extension harnesses.
It's going to take a while, I'm almost done with the February orders and will soon process March. The next is June+July.
It's a moot point anyway, because I won't stock modules with the PlayStation AV Multi output, unless the AV Multi ports magically become available for purchase again :/
So does that mean for those on the 2nd batch of HAS orders (ordered around March) won't get one?
Unfortunately, yes. I didn't have them for the 1st batch either :(
Very nice! What connector are you using for the 4P adapter?
Got my HAS and it's all assembled. Thanks RGB! 8)
Was wondering if this power supply would work.
I'm no electrician and a run down of how to manage power when using this would be really helpful. I don't want to fry the HAS or my arcade PCBs.
Also looking for recommendations on a good control stick that's not ridiculously expensive.
Oh man I want mine so bad. I have 3 PCBs sitting here that I've never even tried, waiting for my HAS!
Same here :D Even re-capped them to be in sharp state when the time comes! Got Haunted Castle PCB, Neo Geo MVS with multicart and IGS PGM with 3 Cave shooters just waiting here...
I think I'm on that March batch, so SOON
Do you need to receive a shipping notification after you have paid your invoice, or does it ship once the invoice is paid?
Konami :) I have TMNT and Sunset Riders. The Sunset Riders came in a converted TMNT cabinet. Here’s a video
If I filled the form in, then a couple days later decided I wanted one of the add-ons so filled it in again.... should I expect two emails or will you notice it's the same person and just send the one order confirmation?
(sorry for any issues caused by filling the form in twice by the way..... :/ )
Looking in to a Jamma extension harness- are they all relatively safe? or are there some that are or are not recommended?
Many of the cheap ones on eBay use insufficiently thin wires for the power, making them no-good for you. There is a really good extender sold on these forums, however if you have a new HAS, I would wait until the makers/sellers confirm it works with it, as @RGB has indicated that the new HAS may have an incompatible edge connector.
No he was just telling me not to recommend extenders as a way to deal with PCB's in plexi cases.
Since he has changed connectors he is suggesting it might connect to a cased PCB without the need for one.
I love @RGB (he knows it and you guys should know it too) and while I haven't tested a "new" HAS...
I respectfully/sincerely doubt this is true!
Being the owner of many different plexi cases (over 10 different styles/shapes) I'm 99.9% confident no matter what JAMMA connecter he used, its just not going to fit the majority of cases.
Sorry Mike you know I love ya man, but I'm so sure your wrong I'll state it publicly.
I recommend @Frank_fjs 's HAS Special Edition JAMMA Extender for HAS and Jammafier users.
Now if you do something like remove the HAS from its case, or don't install the top layer of a PCB's case, sure then it will connect/fit.
As it stands, with both devices encased, you just can't push the HAS in deep enough to plug into the JAMMA edge.
*Disclaimer* I only own the older version 3.1 HAS, so this statement is totally untested with newer (but is believed to be correct by me).
New HAS really does connect fully to stock cps2 and highflow.nl cps3 plexi.
I have to put a book under cps2 to raise it up and then a digipak cd case under the HAS, and for the cps3, I do nothing under the cps3 and a DVD/ps2 game under the HAS.
I’ll take pictures later.
Would it be nicer with a reliable JAMMA extender? Yes. But I don’t have to take the cases apart or anything
As I told you before, the only issue I've got with CPS2 is @twistedsymphony 's 3D printed LCD holder, if you aren't using that then you won't have a problem.
Likewise for the CPS3, the Highflow case is a copy of Jasen's case and yes I too can connect to this PCB without an extender.
I'm talking about MK1, System16, TMNT, System18, M72, CPS1... Yea... NONE of thos!
Also part of my issue might be I've got the HD15 HAT installed (so my case sits a little taller than a stock HAS).
However you slice it, I'm trying to be helpful here... If you intend on getting into plexi cases/3D printed LCD holders you really should get that extender.
Does the HAS have any incompatibilities with System10 boards? Trying to get Mr. Driller 2 running, and while the board's getting power, I'm not getting any video or audio. Kinda weird. The board should be working, and I tried playing Ibara and a CPS2 board, and both of those worked... so trying to narrow down what the culprit is here. Or maybe I missed a power switch on the board itself or something.
I'm using the HAS 3.1, for clarity.
Understood jassin.
Here’s my set up
More
