Home Arcade System
I’m still gleefully and patiently waiting for my email purchase/shipping confirmation. :D
May I please kindly ask - Which is the 1 Player and Coin Button on my Joystick ?
I have connected 1 Undamed DB15 USB Decoder to the H.A.S.
I have connected a Hori Joystick to the DB15 USB Decoder
I would like to know which buttons are the 1 Player and the 1 Coin Buttons ?
Thank You Sir
pin out is in the HAS manual
Thank you for the Quick Reply
Well I was thinking that since I have the Undamed DB15 USB Decoder attached to my XBox360 Pad
I do not need to have any poking around with wires
Does the Start and Select buttons on the XBox360 now become the 1 Player and Coin Buttons ?
Is this how it works ?
Thank you and kind regards Sir
If I were to get this:
https://www.amazon.com/Uxcell-a1501...+breakout&qid=1572230959&s=electronics&sr=1-2
Are the pinouts this?
Checking on this again.... this pinout didn't work....
I am connect my HAS with a VGA Cable to the OSSC using the HAS Video Port
Everything works
but just that I get no sound
Does the VGA Cable from the HAS to the OSSC carry Audio signals transmissions ?
My OSSC is connected to my LCD Monitor with a HDMI Cable
I was wondering if the HDMI Cable carries Audio signals transmissions ?
How do I get Audio with my currently Setup ?
Thanks
VGA does not carry audio. Use the 3.5mm audio jack from your HAS to your OSSC. You may need to alter the settings in your OSSC to set audio input to the 3.5mm audio jack.
VGA connections do not, and have never carried audio signals.
There is an 1/8 stereo mini plug on the HAS, and at least on my OSSC - VGA is V3-IN, and on the other side there is a A3-IN that is also a 1/8 stereo mini plug.
I am guessing you just need a 1/8" stereo male to male cable and you should get audio.
Matt
Everything works
Thanks
As others have said, VGA does NOT carry audio, use the 3.5 jack.
HDMI DOES carry audio out, but of course you need to get audio to the OSSC first.
Finally, if you update your OSSC firmware, make sure you use the version with a lower case "a" with it, example, 81a, 84a, not 81, 84 etc. The "a" is the firmware with audio integrated.
I couldn't find the recommended PSU other than the Meanwell RT-65A.
I am looking for a recommendation for a decent one on ebay in the US that supports more than 65w.
or at US based arcade company that is reliable and ships fast.
Also pre ordered around July, but no email yet. Thought I might have missed out, but it's reassuring to see others still waiting from then.
