Home Arcade System
Kurt Cobain was murdered. ... The forensic pathologist says that suicide was an “impossible scenario”
A forensic pathologist, not THE forensic pathologist. The forensic pathologist who actually got to examine the body, and wasn't just espousing a viewpoint 25 years after the event happened, ruled it a suicide.
@brizzo
Kurt Cobain was murdered. Cobains Dad publicly stated it. The forensic pathologist says that suicide was an “impossible scenario”
Oh really? I had not heard this angle at all... I need to go do some reading.
OK, cool. It's not a huge deal for now, but I'll make sure to get a freesync the next time I'm looking for a display.
Don't forget QHD, the OSSC at its highest 5x supports 1600x1200.
This of course will also work on a UHD/4K but its over kill if this is all you want supported.
If all you have is a HD/1920x1080/1080p 5x mode is cropped and looks like shit (better to use 4x in that case).
we all know Courtney had Kurt murdered
Really? I mean wasn't he rumored to have written more than half of her "Live Through This" album?
I can't see why she should want him dead, he was the only thing propping up her talent-less ass.
@jassin000
Waiting for you to confirm that monitor works with the bracket, make sure input/power ports clear.
Also, are you going to try to relocate controls?
Unless another monitor becomes available, for now this the best/lowest priced one to get with those specs.
Well, if he was going to divorce her, that might be motive. Anyhow, lets just say she didnt do it just like OJ didnt =O :D
I'm looking to secure my Saturn and/or undamned adapters to the HAS, but I'm having trouble finding the right screws to lock them in place. I initially thought I could simply harvest them from VGA cables I'm not using, but the "handles" are too fat, and even the ones I ordered Digikey didn't work. The HAS FAQ states you need "DSUB screw locks with a 10~11mm long thread." Can anyone here please link me to the correct size and length of screw lock?
@opt2not I think had some awhile ago for sale or something. He can probably help you.
Don't forget QHD, the OSSC at its highest 5x supports 1600x1200.This of course will also work on a UHD/4K but its over kill if this is all you want supported.
Gotcha. I'm not ever going to replace the monitor in the cab unless is breaks but eventually I'll get another gaming display.
A lot of games use overscan in the vertical areas on console titles and look good cropped out on 5x.
Arcade PCB'S are a little different and still need compatibility updates for high vertical resolution titles like IREM boards on OSSC even after messing with your active vertical area and POST COAST PLL settings.
The choice to use a 1440p over a 4K is a wise one as OSSC Pro will support 6x intergers off the bat. 240x6=1440. Im sure 9x 60 is not going to make it according to marqs.
If more people test their 4K displays for a true 3x internal interger we could be seeing good results by using 3x on these devices as well further utilizing all the OSSC that are here delaying the obsolete.
What really needs to happen is display manufacturers acknowledging the need for integer scaling options built into the set.
Viewsonic is coming around and Radeon has had compatible integer scaling built into their video cards for years..
Now I kinda want to buy a 1440p display as they are becoming obsolete before we even need them yet for OSSC pro.
WHEN it breaks, not unless... And yea, I'll see ya in about 5 years or less.
Remember if your machine is used it came from an arcade floor where it was on basically 365.
Yes the LCD is a little more durable than your basic LCD TV, but they still aren't rated for anywhere near the life expediency of a CRT.
First the colors/contrast will wash out, then the brightness contrast will go... Before you know it you'll be looking at crap.
Curiosity has bitten.
What are the life expectancies of your typical LCD/CRT, and professional grade LCD/CRT's? Like the on-paper manufacturer ones.
Not for sale, I was giving them away for free!
But i'm all out now.
@ItsACerealWow I got these ones that fit perfectly: https://www.amazon.com/gp/product/B07KWV9YQ9/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
