Home Arcade System
@RGB It’s Marvel Vs Capcom (CPS2). Selecting certain helpers after you’ve selected your two heroes can be done via combination of holding Start & more than one button depending on which helper you’d like to use. Selecting Colossus for example requires holding down Start + LP, MP & MK. I can’t do this with the 4.2 without resetting the settings. Psylocke’s (Start + MK) makes the turbo mode come on.
Is there really no way to disable these with a pre 5.0 HAS? :(
Reactions: RGB
I had a longer break than anticipated :whistling:
HAS is restocked, including the limited colorway bundle (but almost half of the stock is gone already).
Also available:
- RECO V5.1b and accessories
- SNES & SNES Classic Mini to DB15 adapters
- Dual Sega Saturn to DB15 adapter
- HD-15 to SCART cables
Some small changes to the firmware. The HAS finally got a startup screen and some animations. Also, I've added a customer-requested feature that lets you synchronize rapid-fire to the rising or falling edge of the VSync signal.
As usual, grab your gear at https://rgbslab.com/
Thank you!
haha the menu effects are a nice touch, congrats! ^^
any chance you'd consider H/V-size and position adjust for a later revision?
cheers!
cheers!
It's one of my projects that's been on the back burner FOR YEARS! The design has changed a few times over the years, but I'm very close to finally finishing it. Picture position is adjusted with the buttons on the board or using the joystick on the control panel, and I plan to add profiles to save the settings. It doesn't seem to introduce any picture drift (tested it for long hours).
It takes up some PCB space, so I'll likely release it as a separate device.
niice, well count me in for 3🥹 especially if it does size adjustment on top of position adjustment ^^
I'd be interested in a din to vga adaptor for an older HAS of mine, if you can restock those at the same time, since I moved to vga cables only👍
Reactions: RGB
That OLED effect is fantastic and the amount of options on this thing shows someone who really cares about the product.
I suspect we will soon see 'AI slop hardware', but you may not get great support or updated firmware, or future improvements, so my advice is to buy from someone that has a good track-record in these matters, like @RGB
Thank you!
btw if you can re-add something to switch to csync regenerate on it, it would be awesome as I got a Garegga bootleg yesterday and owning a 4.1 and 5.0 HAS I can either get video or sound but not both at the same time😆
btw if you can re-add something to switch to csync regenerate on it, it would be awesome as I got a Garegga bootleg yesterday and owning a 4.2 and 5.0 HAS I can either get video or sound but not both at the same time😆
The shifter should be able to fix it. It fixes issues with the Taito F3 + XRGB-mini combo.
looks like i missed this run, look forward to getting a HAS next time.
any chance you will be restocking the purple/green colorway? it looks awesome
@RGB Is there a reason why the select button of my hard-wired SNES pad with a DB15 pinout doesn’t register on my earlier HAS specifically with CPS1 games? It’s properly wired to the coin input…it’s stumping me given the coin (select button) input seems to work correctly with other boardsets such as CPS2.
On earlier HAS revisions, Select/Coin from the DB15 is wired straight through to the JAMMA coin input, while Start and buttons 1-6 are read by the MCU on the HAS, which then drives the JAMMA lines itself. That means the coin input depends on the pad's own button contact pulling the line low. SNES pads use carbon-coated rubber contacts, which have some resistance when pressed. I don't have the CPS-1 handy to check, but it would appear that it uses stronger pull-ups on its inputs compared to the CPS-2 (or whatever is after the pull-ups needs lower voltage to read logic 0). In short, the rubber contact resistance can stop the coin line from being pulled low enough to register.
https://www.amazon.com/gp/aw/d/B0026PRMVM
That is some special paint you can use to increase the conductivity of the carbon pads. I used it to repair the buttons on a sega genesis arcade stick. It might help with the weak select button.
Dude!!!! This is it, the only other device I have in the video chain is a 3rd party position adjustment. This makes HAS 100% feature complete to perfection and will be an instant purchase for me.
Thank you RGB!
Oh for sure, I never saw that post. Instant buy for me. I play boards on my modern home theater almost every day and something like this would be a dream.
Reactions: RGB
