Home Arcade System
About the "full" HAS supergun solution - sorry guys, not happening soon, too much stuff on my plate at the moment. We can come back to this in a few months. One thing is certain, though - it would be extremely limited in quantity, 3-4 units tops, just to see how it goes for me, but I know it's not something I seek to do in larger quantities.
really love the supergun full setup there
Can you please let me know where do you buy the plastic enclosure box?
Hey @RGB, do you know the reason for some rows of pixels shifting to the right at the top of an image when running some PCB's? I'm running a V2.1 HAS to a PVM 20L5. I'm wondering if the sync regeneration feature in HAS V3.1 might solve that? I can take a picture if you aren't sure what I mean.
Definitely sounds like a sync issue. Perhaps too weak a sync signal. I've noticed the same thing with some PVMs, they seem to be a lot more picky with sync signals than consumer CRTs.
@udongein - What's the game? Might be due to odd refresh rate. I had the same issue with New Zero Team on some TVs.
Just a couple off the top of my head: Detana TwinBee and Raiden (first one). Seems like CPS2 image doesn't have this issue. I can check some of my other PCBs as well if you want.
I have a Detana Twinbee PCB, sold Raiden a while ago. I can test it if you want, I have the 3.1 HAS.
That would help, thanks! Do you have an older HAS to compare it to? Also, what TV do you use?
Edit: I guess you can flip the sync type switch on the HAS and it should be the same as the old ones.
Just an update:
My friend Jeremy doesn’t have access to a brake press so manufacturing a case would be a no go for him. He did say he could make thick, industrial looking faceplates though.
I’m still willing to help out with a drawing, but we need to figure out what exactly we want and a parts list.
Ex: we going flat like a MK30 or boxy like a Sigma or Windy City?
I’m thinking the same, but, that way does take a lot of real estate. My MK30 for example takes up an entire shelf.
I think this is starting to drift off the point of this thread as it is for the HAS system specifically. Perhaps it'd be worthwhile to make a thread in the project ideas section and you may garner support from other readers to provide ideas as well.
An OSSC solution for HAS V1-V2.1 owners or V3-V3.1 who don't want to stack another module:
This one needs an 8pin mini DIN to 8pin mini DIN cable (pins must connect straight through end to end), the same cable you'd use to join HAS and XRGB mini. Get your PCB here - https://oshpark.com/profiles/RGB just two extra parts needed - a male HD15 connector (VGA style) and an 8pin mini DIN connector.
The advantage of connecting HAS to the OSSC via the VGA connector is that it can sync with the Taito F3.
