Supernouht
I have a pair of California Speed 25" sit down cabs. I pulled them out of storage and was getting them set up and linked and they were both working.
They both make a loud "clank" when powered off (which is not uncommon for arcade cabs and I don't know if thatbis relavent) the last time I turned off cab #1 while monitor was working it seemed to be particularly loud. I didn't think much of itbat the time and I don't know ifnit is relavent, but the next time I powered it up it was playing blind with no neck glow.
The cassis is a Neotec nt-2501 and I had a spare nt-2501 that I bought off ebay but had not tested yet. So I installed the ebay chassis and same result, no picture, no neck glow. So just to make sure the problem was the chassis I decided to swap the working chassis from cabinet #2 into cabinet #1. The chassis in #2 is a Sharp Image and after I installed it in cab#1 there was still no neck glow and no image. So then I put the Sharp Image back into cab#2 where it was previously working and now that one also has no neck glow and no image.
Is it possible that cab#1 is somehow killing monitor chassis? The power at the monitor connection measures at 120v and I hooked the crt to my tube rejuvinator and it seems good.
So maybe the ebay chassis was already bad and maybe the Sharp Image chassis from cab #2 just decided to die for no reason right when I installed it in cab#1, but I'd though I'd get some additional opinions.
Now I have another Sharp Image chassis with monitor collapse (but powers on with horizontal white line on screen) that I pulled from another game. I installed this into cab #2 and it powers on and I get a neck glow and a white line. So now my next step would be to install this chassis into cab #1 and see if this chassis gets killed too, but I'm a but hesitant.
Am I missing something, anything I should check that maybe I haven't?
Thanks!
Thanks!
