hoagtech
How much for flip the table?here Thursday
Yeah, I've never had the urge to own such a pointless game, but I do...How much for flip the table?here Thursday
"Something that is reasonable to do at home" is really subjective. Are you experienced in soldering and general electronics repair?I don't mind learning how to do something that is reasonable to do at home - but I also haven't done much CRT work before so it'd be a learning process for me.
Yep...and if you can fit those, you can work in a PFX as well, even if its' not ideal.You have options, depending on what you’re willing to accept. I have a Makvision flat CRT is my Blast. It’s far from ideal, but it works for now. I have a Wells Gardner D9200 waiting for me to swap it into the Blast.
Net City will have the same problem.I would call a Blast City an advanced level cab for the following reasons....
Monitor - Semi curved tubes are NOT easy to find...so if yours is burnt or dying, its going to mean a lot of work to hunt a replacement, or tube swap.
Never had an issue with a Blast PSU. I've had SUN PSUs die on me, Blasts no. Easy to recap even if you've just picked up a soldering iron.Power Supply - due to the harnessing, the PSU block is also quite the pain. Cabinets like the Aero, can easily have a different PSU adapted in. Blasts make this extremely difficult.
If you don't want to run wires straight from kick harness to the buttons (which IMO is perfectly fine), you can connect them to CN8 on the IO and you have them then on the 10-pin AUX connector next to the 1P and 2P controls. What cab is somehow better? Astro for one are exactly the same, just with a different connector.Blast I/O pcb - excellent for versatility, but another complication in creating things like cps2 kick harness adapters or other options.
Monitor is admittedly harder to get out, but I can still take out a monitor and put it back in maybe 1/10th of the time it takes me to pull out a monitor from an Astro. No, I don't want to do it daily, but honestly, unless the cab has a rotate mech, it's not something I want to do with any cab. Also, top tip for owners, when you have the monitor out, make sure the bolts are correctly aligned. Realigning them is really easy to do and makes the procedure waay easier in the future.Cabinet - Monitor is difficult to get out, and must come out to be worked on. Cracks at Control Panel intersection with cabinet, fiberglass unibody, makes getting to things a pain and damage harder to repair.
This is the honest take away. I love my blast and think most here agree we just think it's complications are slightly above entry level. Its a great cab for anyone with the infrastructure set up to tackle it's challenges.I think for my use I’ve settled on Astro/New Astro since 15khz usage is most important to me and monitor issues scare me the most.
I do however appreciate the impassioned defense of the Blast City!
Sounds like a fine cabinet, but just not for my first one.
