Yes sure: https://makerworld.com/en/models/1223740-mahjong-controller-mvs-neogeo#profileId-1241107This is amazing, definitely going to build one. Thanks for your work. Do you have a 3D print file for your shell?
Do you have a specified screw size?Yes sure: https://makerworld.com/en/models/1223740-mahjong-controller-mvs-neogeo#profileId-1241107
If you goin to use this on AES, close the jumper on board.
Do you have a source for the zbf253d's? I can always scavenge them from failed boards, but I don't know of anyplace they can be purchased...Easy:
1) Get OUT pin here.
2) from side connector to 74ls06 input :
3x 22ohm resistor
1x 74ls06
3x zbf253d
3) out from zbf253d to DB15
pin 10-2 and 9
I take it from a mv2f failed board, but you can take from any model of mvs.Do you have a source for the zbf253d's? I can always scavenge them from failed boards, but I don't know of anyplace they can be purchased...
Mouser always lists them as “restricted inventory”, so the times I’ve needed them I always have to scrounge. And yeah, never been too clear on their purpose beyond the FCC saying they need to be there.I take it from a mv2f failed board, but you can take from any model of mvs.
i'm not sure about direct substitute:
https://www.mouser.it/ProductDetail/TDK/MMZ1608B102CTD25?qs=pvNC7ksEVIefM6hx9JP%2Bzg==
its a Noise-Suppression Filters so maybe you can try without it![]()
CON1
pin 1 - NC (ground)
pin 2 - NC
pin 3 - pin 9 of 2up joystick port
pin 4 - pin 2 of 2up joystick port
pin 5 - pin 10 of 2up joystick port
pin 6 - pin 9 of 1up joystick port
pin 7 - pin 2 of 1up joystick port
pin 8 - pin 10 of 1up joystick port
Can pull VCC from TP2
Could you update the PCB to support kailh choc switches or let us know what type of switch we need to use?
Or do you have the actual project file so I can change it myself please?
