Mark of the Wolves Reverse Engineering thread
Are you going to be building a cart with your patches soon? You might want to try the mame version I uploaded earlier here that has the SMA bank switching disabled. If I remember correctly, it was throwing the same error code screen as my mvs. The original Mame build exe had a different error address.
Edit: after reading the my posts again, think it only disabled bank switching in the fixed layer. That wouldn't really be useful here.
I'll try it out. Most people using this for vortex will use the p1+p2 file (the 5Mb file called prom) The CRC32 for it is:
before patch: 7D5DFDF9
after patch: 3DAEC1BA
Can you confirm @Misos?
Also, garou is still broken. Vortex can't compile with just the fix here. Even when I trim the 512k srom to 128, the compiler says:
GenROM: .......................................Error: bankswitching mode 4 in garou is not supported!
I think the problem is in the fpga file. garoub says "10" in this file. garou says "45". I'm not sure if changing 45 to 10 is the correct fix.
Yes, that's correct.
It seems the FPGA code has to be modified first before it runs on the vortex cart.
Can you test Kof2000 for now? Use kof2000n.
Kof2000n seems to work fine in software. One of the things I like about the Vortex compiler is that it can generate MAME compatible ROM files + neogeo.xml hash file for you to test the output in MAME.
I was able to validate kof2000n this way in the latest version of MAME. Garou with your patch on the other hand causes MAME to go into a boot loop.
I don't believe the vortex compiler uses the fpga file besides sanity checking to make sure the ROM will work.
According to DarkSoft, the fpga file is really for his flash cart. The content value is as following. If you're not sure, "10" is a good value (which is what I set it to me)
Code:
1st digit indicates bankswitching mode:
0 = no bankswitching
1 = standard bankswitching
2 = neo-pvc bankswitching (F9 & F8)
3 = neo-sma KOF99 bankswitching
4 = neo-sma Garou "KF" version bankswitching
5 = neo-sma Garou "KE" version bankswitching
6 = neo-sma Metal Slug 3 bankswitching
7 = neo-sma KOF2000 bankswitching
2nd digit indicates graphics mode:
0 = CROM full address
1 = CROM zero 1 MSB
2 = CROM zero 2 MSBs
3 = CROM zero 3 MSBs
4 = CROM zero 4 MSBs
5 = NEO-CMC SROM bankswitching (42 version)
6 = NEO-CMC SROM bankswitching (50 version)
3rd digit indicates audio mode:
0 = VROM+PCM mode
1 = VROMA/VROMB mode
