I mean... its not like its THAT expensive on MVS anyways.not having any fear of original Garou to break
You can get one right now in stock from Tops for 50000yen which is like 300usd. You can prob find it cheaper elsewhere if looking around a bit.
Please let me know where if you come across one for that priceI mean... its not like its THAT expensive on MVS anyways.
If AES+ Garou comes really full decrypted, that is going to be fucking incredible if it is dumped.I'm willing to bet that a 1:1 copy of this neo-sma will not be made because the cassettes are low budget.
I'm betting on a software solution.
I've thought about this before and it will be fun to see the people dump that comes out.
I wrote it in the post?Please let me know where if you come across one for that price(yes I'm serious).
Well, I actually already have a patch for Garou. Again, tested and working in Mame and based on the work of darknezz19 and programmed by Claude, I only did the testing. But I would like to confirm it's working in real hardware before programming it into a 161.So its time ?
Its time do some work on Mark of the Wolves and NEO-SMA with current IA ?
Please tell me more, you work around neo sma or it's a path on prototype ?Well, I actually already have a patch for Garou. Again, tested and working in Mame and based on the work of darknezz19 and programmed by Claude, I only did the testing. But I would like to confirm it's working in real hardware before programming it into a 161.
I don't know if I can post the roms patched here, but if it's allowed I can share the links of Garou and Kof2000.
It's just a workaround. The goal is to run it on the 161-in-1, but I need someone to test it on a flashcart first.Please tell me more, you work around neo sma or it's a path on prototype ?
