nem
Finland
So the PSU in my other Hydro Thunder stopped working. Opening it up I noticed the caps had started to leak. I recapped it, but the damage was already done. I recapped the other one, which should hopefully keep it going for a while. It's a standard PC PSU, so shouldn't be too hard to replace. The specs are pretty beefy though.
CWT-300ATX
Input: 115V 7A / 230V 4A
Output: DC 3.3V 14A, 5V 30A, 12V 8A, -5V 0.5A, -12V 0.5A, 5V SB 1.5A
Main PCB:
Code:
Capacitor       Qty  Location           Diameter
1uf     50V     4    C3, C4, C7, C102   5mm
2.2uf   50V     2    C5, C8             5mm
10uf    50V     1    C9                 5mm
22uf    50V     1    C06                5mm
47uf    16V     1    C12                8mm
470uf   16V     1    C104               8mm
680uf   200V    2    C1, C2             25mm
1000uf  10V     1    C02                10mm
1000uf  16V     1    C13                10mm
1650uf  16V     1    C15                10mm
2200uf  10V     2    C16, C17           10mm
Sub PCB:
Code:
22uf    50V     1    C10                5mm
470uf   16V     2    C12, C13           8mm
