I think that is wrong.hey guys, I was curious about something in regards to wiring for power. I've recently read somewhere that i should run one of the two grounds from the minigun power cable to the field ground(FG) terminal on the psu, which a proper 3 prong power cable is already utilizing.
Is this accurate?
This is how I do it.SabreAZ said:I normally combine both ground wires to one spade fork and run it to one ofvthecregular ground terminals. I also see many others do this over the years.
in my case, an RT-65aWhat is the PSU in question? Some have earth and DC ground connected internally via a filtering capacitor, which is why continuity won't buzz through on a multimeter.
Can it be connected to a VGA monitor?In case it isn't obvious, use jumper shunts on the sync booster PCB to select between CSYNC or HV sync output.
1 x jumper shunt for CSYNC:
OR 2 x jumper shunts for HV sync output:
Depends on the sync range supported by the monitor.Can it be connected to a VGA monitor?In case it isn't obvious, use jumper shunts on the sync booster PCB to select between CSYNC or HV sync output.
Yes. The proper VGA hsync frequency is 31kHz. Many VGA CRT monitors will not accept an hsync significantly lower. Such as 15kHz hsync for 240p signals.@the Goat a vga crt monitor?
Got it, Thanks.Yes. The proper VGA hsync frequency is 31kHz. Many VGA CRT monitors will not accept an hsync significantly lower. Such as 15kHz hsync for 240p signals.@the Goat a vga crt monitor?
