I kind of agree with you. Personally, I don't utilise PCB feet / standoffs as:I'm not certain I like the tabs for the screw mounts. I'm going to have to rethink the design of my case to accommodate those, since I'm using the screw holes to bind it together. Or just have them sticking out of the case, if that's possible? I understand how they can be a cool feature for standoffs and they leave more room for the layout. I'm particularly worried that the tabs closest to the JAMMA connector my come in conflict with the screws coming from the JAMMA connector perpendicular.Here's where I'm heading for version 2.0:
I believe this approach fixes the DB15 spacing issue and provides additional mounting options without comprising the DB15s being centred nor the general design and layout that I like. I might move the tactile switches to the farthermost right edge too. Any feedback welcome, the sooner the better before I begin finalising the design and fabricating some test PCBs.
- DB15s further spaced apart to resolve 2 x Undamned encoders not fitting side by side.
- Tabs with 3mm holes added to each corner of the PCB to accommodate PCB feet / standoffs / mounting / plexi base attachment etc.
Once I have the layout sorted, my next step will be a 3/4 player expansion board and down the track a video expansion board. The video expansion board will provide composite video, s-video, RCA audio output and a VGA connector designed for use with an OSSC.
Version 2 will accommodate the following voltmeter.Can anyone suggest a suitable voltmeter part that can be added to the jamma connector. Digi key part preferred. Thanks
If you ever come up to Sydney msg me i'd gladly take you for a beer or invite you to play some games ! cheers
This is using a digikey Meanwell 85 PSU.
Thanks for taking my comments into consideration, I'm happy to hear you aren't a fan of the standoffs eitherI kind of agree with you. Personally, I don't utilise PCB feet / standoffs as:
1. The Minigun is light weight and compact and doesn't place significant stress on the jamma finger of the game board.
2. All my game PCBs are at different heights so PCB feet can actually make things worse in some scenarios. E.g. CPS2 sits lower, some boards don't have feet at all etc.
3. Since you've designed an awesome 3D printable case, it kind of negates the need for holes on the PCB.
If I omit the tabs it should make your life a lot easier re the 3D enclosure. You will need to space the DB15s 1mm further apart and accomodate for the tactile switches being shifted over to the right. I love the case you've designed, and am very near ordering some PCBs for version 2, I'd gladly send you an assembled V2 at no cost if you'd be kind enough to redesign the 3D case to suit?
Like you said, the minigun is small enough not to cause significant stress on the JAMMA connector unless someone really tugs on a cable or leans on it, but that is the same with any supergun really. For most of my boards without standoffs, right now the minigun just lays flat on the table, no need for support at all.The third (in my case it was a yellow wire) is often used to accommodate higher voltage readings (30-100v), in the case of this PCB, you dont go any higher than 5 or 12v, so I removed the yellow wire and bridged the yellow and red wires on the actual voltmeter itself.@Frank_fjs Would something like this one work for the volt meter? If not can you provide link to one that will please. Also i see them coming 2 and 3 wire version. Will it matter?
Ebay Volt Meter
Turns out this is a bad idea. The HD retrovision genesis cable uses composite for sync not csync.I'm planning to use a HD retrovision Genesis cable
If you have an attenuated 75 ohm csync signal, you can connect that to composite and the HDRV cables will accept it just fine. Their design strips csync from composite.Turns out this is a bad idea. The HD retrovision genesis cable uses composite for sync not csync.I'm planning to use a HD retrovision Genesis cable
I'm using a Retrotink now and don't have any scart stuff yet, guess its time to try a shinybow?
Thanks @Frank_fjs for the info. Very helpful.Version 2 will accommodate the following voltmeter.Can anyone suggest a suitable voltmeter part that can be added to the jamma connector. Digi key part preferred. Thanks![]()
I have a few of thoseA simpler idea re feeding CPS2 stereo audio, grab one of Tim Worthington's NES RGB scart plug kits.
I used to sell em pre-built on ebay, but last time I visited Tim he had no stock. Good call forgot about the input-audio socket on those.I could be wrong but I'm pretty sure you'll need to wire up your own. I don't think there's any JST XH to CPS2 cables out there with the correct pinout already.Hey Guys! New member here and proud owner of a @arcadeqc hand-made V1.7 Advanced MiniGun Supergun
What a nice project @Frank_fjs . Thx for everything you do
I'm wondering if someone have info/pics of the Minigun used with a kick harness. Does it need a custom wiring or a pre-made harness to supergun cable exists on the market?
thx
Simon
