R8, R9, R10
That capacitors are for AC coupling. It's considered a good practice to include them.Have you considered removing the 8 optional output capacitors?
I have tried the circuit both with and without them, and can’t see much of a difference in the output.
The datasheet for THS7374 has them as optional. Having them there is probably beneficial in some scenarios, but THS7374 boards ive seen for other usecases (RGB modding consoles and stuff) dont have them.
Ah, this is a very fair point. I've been pretty much only using OSSC for THS7374 outputs, and there I don't really see much of a difference at all when using DC coupled outputs.Results may vary pending monitor and what other devices you have in the chain such as the OSSC.
so 3 players for now
I use the minigun directly with my Sony BVM monitor -- no OSSC/Framemeister. But the BVM is not a consumer display.I'm hoping I have just fundamentally misunderstood what I need for this to work, but I'm failing to get any video out of the Minigun hooked up to an MV-1C. Does the RGB SCART output require something like the OSSC/Framemeister or the RetroTINK RGB2COMP in order to convert properly to consumer-level displays?
Well, that's really cool. I do have a pair of Trinitron TVs that could be modded at a later date. Currently, though, I am really hoping to get this rolling with a stock TV before I spend too much time going RGB-crazy. If this ends up a win, though, I'll probably go plenty crazy later.I've hooked my minigun to an RGB modded Trinitron using a MV-1FZ and it worked no problem, perhaps a bit of overscan but no real issues.
Yes. Consumer TV don't accept RGB signals. So a OSSC or a RGB2COMP or a supergun that can use a Genesis HD retrovision cable is necessary.Does the RGB SCART output require something like the OSSC/Framemeister or the RetroTINK RGB2COMP in order to convert properly to consumer-level displays
Scart to composite adaptor is on a RGB to composite converter so it's normal it doesnt work.p SCART-to-composite adapter
this could work but the those cheap converters processes 240p as 480i and also the MVS output @59.14Hz....this can explain why it looks like trash on your TV!SCART-to-HDMI video converter
You have a good cable!NES RGB SCART cable
