https://twitter.com/misteraddons/status/1466436326622851072?s=21Any word on when more of these will be available?
I missed my chance on the first round.
Did you reach out to MisterAddons through the contact form of his site like I mentioned in Post 133? He’s waiting to hear from you to get you swapped out.
Yes, thank you. He asked me to make a video to verify if my setup isn’t correct. I posted the link here as well. I’m thinking I’ve misunderstood the MISTercade’s power requirement. I think the power supply for my 60-1 is no longer utilized once I connect my JAMMA to the MISTercade.Did you reach out to MisterAddons through the contact form of his site like I mentioned in Post 133? He’s waiting to hear from you to get you swapped out.
Just saw the video and yes you need to power the Mistercade through the jamma edge, 12v specifically. So the capped power wires on your harness need to plugged to the molex on PSU. Do not use the PSU that comes with the DE10 nano.Yes, thank you. He asked me to make a video to verify if my setup isn’t correct. I posted the link here as well. I’m thinking I’ve misunderstood the MISTercade’s power requirement. I think the power supply for my 60-1 is no longer utilized once I connect my JAMMA to the MISTercade.
The DE10-Nano comes w/ a power supply. Is that power supply insufficient for this application? Is it possible that both problems w/ the unpowered speaker and over-saturated colors on the monitor associated? I’m guessing here that those capped plugs coming off the JAMMA are alternative ways to connect +12, +5, and ground…which the power supply for the 60-1 seems to have an empty molex. If I can connect the two, maybe my power issues are solved?
Thx for the question. So I got that cabinet from http://www.fatcatamusement.com/@BabaYaga326 Who did you buy that cab from? Do they have a site/link?
So yeah, it helps if I read the fine print on the MISTer Addons storefront, doesn’t it? LOLJust saw the video and yes you need to power the Mistercade through the jamma edge, 12v specifically. So the capped power wires on your harness need to plugged to the molex on PSU. Do not use the PSU that comes with the DE10 nano.
Also, you should unplug power to your 60n1, since you will be using the mistercade.
.So yeah, it helps if I read the fine print on the MISTer Addons storefront, doesn’t it? LOL
Power Notice:
- REQUIRES +12V 1A FROM ARCADE PSU
- +5V power generated from the +12V rail
- +5V and -5V cabinet power supply rails are loaded for a steady 100 mA current
Hey friends,
Final versions of the MiSTercade mount/brace are on Thingiverse. Feel free to do whatever you want with them as they're a gift back to the community for all the resources I've been the beneficiary of. If you do decide to sell them, a link back to the thingiverse page would be nice.
Hey friends,
Thanks for sharing, but has anyone been able to successfully download it? I tried yesterday, and today, and I get a 404 every time. Logged in or not.Hey friends,
Hey, sure! DM meWow, looks sweet! Can I buy a print from you @TodoRojo?![]()
Hey Aurich, thanks for letting me know. I'll try re-uploading them again tonight to make sure they can be downloaded together. I have a feeling it has to do with the amount of times I updated photos and STL files.Thanks for sharing, but has anyone been able to successfully download it? I tried yesterday, and today, and I get a 404 every time. Logged in or not.
Hey, use the contact form on my site and I’ll help troubleshoot. A few microcontrollers have intermittent connection issues and need replacement. I caught most but not all of them during the QA process.Hey all - have a weird issue with my MiSTercade in an Astro City. I installed it two nights ago and everything was great and worked fine. This morning I turn on my cab and I can't get any controls to respond at the main menu. P1, P2 side, nothing does anything. I've tried leaving the cab on and rebooting the MiSTer via the physical buttons, and I've also tried powering off and on the entire thing.
If I use a keyboard, I can still get the menu to respond. Seems like something is amiss with my controls via Jamma, or the controller on the mistercade that decodes them? Haven't been in the cab since Friday when this was working so nothing has changed there.
Anyone seen anything like that?
