Asure
Midway loves obfuscating jumps.. Here's the example in MK1:
Yes that almost spells ED Boon.
Basically A0 is filled with some values, juggled around into A1, then BEEB0 is subtracted, A1 is put back to A0, and finally, we jump to A0 (which is near the code below.)
Anyway how do we fix this if stuff goes 'wrong' on our different ASIC:
Should be:
I've not found any crc check yet in this one and that's one of the reasons this patch is not released, i get some strange things in regards to the Coin drop sound speed increase and Game over screen looks wierd sometimes. There is several more JUMP A0 in the code and i'm not 100% sure about this patch. The Turbo Ninja hack also leaves this check intact, maybe for the same reason. I need to look into this more some time. For now, it runs and plays..
Code:
FFCAF9C0: 09E1 DB00 000E MOVI EDB00h,A1
FFCAF9F0: 0D3F 00EC CALLR FFCB08D0h
Code:
FFDB5410: 09C0 3008 MOVI 3008h,A0
FFDB5430: 0D5F AB00 FFC8 CALLA FFC8AB00h
FFDB5460: 0D5F 9C90 FFC8 CALLA FFC89C90h
FFDB5490: 09C0 02EE MOVI 2EEh,A0
FFDB54B0: 0D5F B180 FFC9 CALLA FFC9B180h
FFDB54E0: C819 JRC FFDB5680h
FFDB54F0: 09E0 1500 FFEB MOVI FFEB1500h,A0
FFDB5520: 4C01 MOVE A0,A1
FFDB5530: 0D01 114F FFF4 SUBI BEEB0h,A1
FFDB5560: 4C20 MOVE A1,A0
FFDB5570: 09E1 55C0 FFDB MOVI FFDB55C0h,A1
FFDB55A0: A22F MOVE A1,-*SP,1
FFDB55B0: 0160 JUMP A0
FFDB55C0: 4C00 MOVE A0,A0
FFDB55D0: CA0A JREQ FFDB5680h
Code:
FFDF2650: 09C0 7000 MOVI 7000h,A0 ; a whole bunch of stuff to obfuscate the read from 'hidden ram' as presented
FFDF2670: 0D5F B040 FFC9 CALLA FFC9B040h ; by the ASIC chip from 0x1b00000 -> 0x1b6ffff
FFDF26A0: 2480 SLL 4h,A0
FFDF26B0: 09EE 0000 01A0 MOVI 1A00000h,A14 ; not 1B00000 right!
FFDF26E0: 400E ADD A0,A14
FFDF26F0: 18E0 MOVK 7h,A0
FFDF2700: 0D5F B040 FFC9 CALLA FFC9B040h
FFDF2730: 1420 DEC A0
FFDF2740: 24C0 SLL 6h,A0
FFDF2750: 0B20 2970 FFDF ADDI FFDF2970h,A0
FFDF2780: 860B MOVE *A0,A11,1
FFDF2790: B601 0020 MOVE *A0(20h),A1,1
FFDF27B0: 0BE1 FFD7 SUBI 28h,A1
FFDF27D0: 2501 SLL 8h,A1
FFDF27E0: 0B2E 0000 0010 ADDI 100000h,A14 ; lets add 10000 to 1A00000 and end up at 1B00000 ;)
FFDF2810: 802E MOVE A1,*A14,0
FFDF2820: 85C0 MOVE *A14,A0,0
FFDF2830: 0B80 81FF FFFF ANDI 7E00h,A0
FFDF2860: 2EE0 SRL 9h,A0
FFDF2870: 9561 MOVE *A11+,A1,0
FFDF2880: 0B41 FF00 CMPI FFh,A1 ; check if A1 = FF
FFDF28A0: CA0A JREQ FFDF2950h ;if A1 is equal to 0xFF we go to FFDF2950 (we're done reading, and we never had a wrong answer from asic.)
FFDF28B0: 4801 CMP A0,A1 ; Not done reading security values. Lets compare: A0 and A1 should be the same.
FFDF28C0: CB01 JRNE FFDF28E0 ; this is where we goto if things are not the same.. (i.e. we trip security.)
FFDF28D0: C0F4 JR FFDF2820h ; back to our checking asic loop.
FFDF28E0: 09C0 0025 MOVI 25h,A0 ;proces ID
FFDF2900: 0D5F 37D0 FFE1 CALLA FFE137D0h ;start that process (probably a seccal_trash equivalent like we saw in NBA jam.)
FFDF2930: 1820 MOVK 1h,A0 ; also let's shove an additinal 0x1 into A0 to let the routine that called us know we failed.
FFDF2940: 0960 RETS ; back to where we came from (in failed state)
FFDF2950: 5600 CLR A0 ; basically our exit routine if all is well and nothing failed. Clear values in reg A0
FFDF2960: 0960 RETS
Code:
FFDF28C0: CB01 JRNE FFDF28E0 ; this is where we goto if things are not zero (wrong).
Should be:
Code:
FFDF28C0: CB08 JRNE FFDF2950h
FFDF2960: 0960 RETS
