I have an OK Baby cabinet that I've been rewiring. It has an MS9 tube and chassis that are not original.
The CRT is mounted to a custom frame for the cabinet which is isolated from any of the other metal parts. The chassis sits separate on a wooden shelf. There's no single metal frame around it like in an Astro City.
The MS9 chassis has a little ground connection that's supposed to connect to the metal monitor frame.
If I tie the chassis's ground to FG and CRT frame to FG I get horizontal bands at the bottom of the screen and diagonal noise flowing across the screen. If I remove the two connections to FG, no problems.
1. Is it safe to float the monitor? I assume so since the frame in my Astro isn't grounded either. So far after disconnecting the connection to FG I just notice a little static buildup which seems normal.
2. Should I connect the chassis ground to the monitor frame? This seems like a good idea to replicate the connection that would be there if it was mounted on the normal metal frame. There's already continuity through the ground strap around the monitor though.
3. I have a Meanwell power supply. There is no continuity between FG and Com (logic ground). I've seen threads suggesting jumpering FG and logic ground. Thoughts?
