you all are great professionals here.. managed to move on. Is ZMC2 worth checking?thank you for the guide.
I check the lines
I check the lines
Yes. It's what muxes the graphics. On the 2 slot you can see that each of the two NEO-257s takes the graphics data from the appropriate slot and sends it to the ZMC2. The ZMC2 muxes and sends it on to the chipset for processing/display.Is ZMC2 worth checking?
ohhhYes. It's what muxes the graphics. On the 2 slot you can see that each of the two NEO-257s takes the graphics data from the appropriate slot and sends it to the ZMC2. The ZMC2 muxes and sends it on to the chipset for processing/display.
hmmmHello,again.
unfortunately I made a mistake. I thought I would clean the pcb from the black glue stains (circled in the picture). After that, unfortunately, the pcb did not start, only unibios 4.0 starts (all functions work flawlessly in unibios 4.0). the original bios only gets to the green screen. the repair eprom shows no errors. I checked the cleaned parts but I didn't see any signs of wear. can you help me where to look for the error?
Thanks
yes, this line between the D4990 clock chip is very long. I checked this line and it was fine. the error was still there. After I removed the screw, all errors disappeared.Green screen of death = problem with the clock / calendar circuit. Look for power on pin 14 of the D4990 clock chip over on the opposite side of the board from the battery. Then check the tiny round clock crystal and 2 little green capacitors next to it.
thank you for writing your experience.On my repair notes, I have Calendar crash (stuck on green screen) causes as :
-RTC chip faulty
-RTC / Save RAM battery power line.
With diagbios you can test if RTC pulses are in sync. IIRC Unibios just bypass Save and RTC tests
I had a 1F board where RTC test was wonky, but with the logic probe I saw the 1s ticks on the RTC test point. Turns out a corroded via on the battery power line, and somehow the logic probe was able to kickstart the RTC ! That trace went coast to coast, and on the MV2F it does as well I think, battery is top left, RTC is bottom right. So check that trace.
That is very odd. Either it was cutting into a trace or it's flexing the board a bit and causing a bad trace to go open.I removed the spacer screw and it started. it works again.
yes, that's weird. maybe it's the water too. I also washed the glue spots with water. I dried it properly. I do not know.....That is very odd. Either it was cutting into a trace or it's flexing the board a bit and causing a bad trace to go open.
I use these. I took another board. same type.It looks like you are messing with the wrong vram chips. The address in the error is 0x000000, which is the start of the slow vram chips. The chip/lspc pins you listed above are for the fast vram chips.
I changed these tooThere are 4 vram chips on the board, 2x slow vram and 2x fast vram. The error address points to the slow vram chips, but you replaced the fast vram chips. The slow vram chips are the ones between the LSPC and the fast vram chips.
Then use Windows Calculator... 0400 hexadecimal is 0000 0100 0000 0000 in binary. The upper 8 bits has a stuck bit. You either have a short or an open on that pin... or multiple bad RAMs. You could also have a popped pin on the LSPC chip for that bit.I changed these too
I checked the lines between RAM and LSPC, each line is connected to a pin.Then use Windows Calculator... 0400 hexadecimal is 0000 0100 0000 0000 in binary. The upper 8 bits has a stuck bit. You either have a short or an open on that pin... or multiple bad RAMs. You could also have a popped pin on the LSPC chip for that bit.
