MVS 2 Slot Repair Help
I warmed up.....
little deacidification.
if this ever works.....?...😀
a quick question..... i found a faulty 74AS245 ic
can I put a 74LS245 instead?
MV4FT
No. Maybe a 74F, but not a 74LS. The fanout capability of AS is much much higher than LS.
unfortunately I found this 74LS245. I installed this instead until I get a 74AS245. is this causing this error?
I warmed up.....
I don't think I need this for life. which is bram (Back up Ram)? 1-2-3-4? if bram=back up rom, is ram 1 or 2 or 3 or 4 at fault? or do you have to look for the error in the lines?
its usually going to be something wrong with the OE signal going to the ram chip
Backup RAM is the RAM that has pin 28 NOT connected to the +5 JAMMA Edge Connector for power. There are 2. One is upper that is connected to the upper 8 data bits and the other is lower and is connected to the lower 8 data bits of the CPU. Check continuity to ID which RAMs are which. :)
thank you for the guide.
I check the lines
