MVS 2 Slot Repair Help
r67055
Hungary
Hi!
I want to ask for help.
I have a MV2F MVS PCB. I put any game card in it, it just shows a grid image.
I cleaned both slots. I checked the corrosion lines. but I found no signs of damage. I took out the Diagnostic Rom. I see all tests as good.
Does anyone know what I can do after this?
Thanks
maybe you can see something?
it would be a lot of work to change the sockets :((((
which one should I start the exchange with?
this pcb was put away in a box about 2 years ago together with a 4 slot mvs. both were still working. I just took it out and both were faulty. inserted cards do not start. I don't understand what could have happened.
I cleaned the sockets.
I thought I'd check it out. but all pins are in contact.
I used the multimeter on both sides of the pcb.
What I normally do in this situation is to use unibios with a known working cart inserted. At unibios's crosshatch screen there is an option to do the memory viewer, pick that then scroll down to address 000100. At that location on a working cart/board you should see "NEO-GEO" on the right as seem below
If there is a data/address issue between the board/cart the NEO-GEO will be corrupt. What the corruption is can point to whats causing the problem.
Thanks for the information.
I started looking at UNIBOIS 4.0 under "MEMORY MAP" yesterday. I didn't know what to look for, unfortunately there is no working board. I'll look again tomorrow.
so should I go to 000100... if I see the inscription "NEO-GEO", what does it refer to?
That "NEO-GEO" is part of the header on the program rom on the cart. Getting crosshatch with a cart inserted indicates there maybe a data/address issue for the board talking to the program roms of the cart. If there is some data/address issue it will likely cause that "NEO-GEO" string to be wrong in some way.
unfortunately, I could only extract data from slot 2.
if I put the card in slot 1, the screen is black.
If I understand correctly, there is something wrong with the mvs Board. What should I do now?
If you compare the expected NEO-GEO with your LEM-EEM it points the were the issue is.
Code:
       HEX          |  ASCI
4E45 4F2D 4745 4Fxx | NEO-GEOx
4C45 4D2D 4545 4Dxx | LEM-EEMx
Then converting the hex values into bits you can see the specific bit that is causing the problem
Code:
 HEX |       BITS
4E45 | 01001110 01000101
4C45 | 01001100 01000101
4F2D | 01001111 00101101
4D2D | 01001101 00101101
4745 | 01000111 01000101
4545 | 01000101 01000101
4Fxx | 01001111 xxxxxxxx
4Dxx | 01001101 xxxxxxxx
So looks like data bit D9 is stuck low.
Unfortunately, I don't understand the bits. Therefore, unfortunately, I don't know what you wrote means.
I don't have the knowledge for it.
I don't know where to start in discovering the error.
I started to check the D9 Data line, on the M68000, leg 60. It is not at a low level.
here I realized that we are not thinking the same thing.
You are almost there. The D9 data line between the cart slot and the CPU is not direct. It will got through the NEO-G0 to the left of slot 1. This IC is picking which of the 2 slots data lines will be passed to the CPU.
https://wiki.neogeodev.org/index.php?title=NEO-G0
https://wiki.neogeodev.org/index.php?title=File:Neo-g0_J4_pinout.png
I would also verify you are see the same issue with multiple carts. Its always possible the issue is the result of a bad cart.
I have 2 test cards. both worked. both write the same code for 100 addresses "LEM-EEMx". the card is not at fault. I also started looking at the NEO-G0. is in contact with the CPU. Tomorrow I will replace it with another NEO-G0. We'll see what he does.
Before you swap I would verify continuity between the slots data lines and the NEO-G0. It could always been a corroded/cut trace.
