Will you be selling the modified rom board and whatever else needed to run for the existing CPS1.5 multis?
ok, can you please let me know when its up for sale.ok, can you please let me know when its up for sale.
Thanks for the reply.@GeorgeSpinner I doubt that's intentional. Can you swap A boards? Is the dip broken or actually ignored (you can check with a multimeter). The creator @lydz is more easily reached via his email v99204@qq.com
Thanks for the tip.That wire is for auto reset, when you change games it automatically resets and starts playing the new game instead of you needing to power cycle.
The seller recommended I try swapping the A boards, so I did.@GeorgeSpinner I doubt that's intentional. Can you swap A boards? Is the dip broken or actually ignored (you can check with a multimeter). The creator @lydz is more easily reached via his email v99204@qq.com
The games above I've marked yes are those I have that I can confirm support continues. Pretty sure all CPS1 games do.Thanks for the tip.That wire is for auto reset, when you change games it automatically resets and starts playing the new game instead of you needing to power cycle.
The game is not retained after power off, so I can see why this is required. Wouldn't work any other way.
Do you have one of these boards? can you continue in the following games?
3 Wonders
1941
Captain Commando - Yes
Carrier Airwing
Final Fight - Yes
Knights of the Round - Yes
Magic Sword
Mega Twins
Mercs
Nemo
Street Fighter 2 - Yes
Street Fighter 2 Champion Edition - Yes
Street Fighter 2 Turbo - Yes
The King of Dragons
UN Squadron
You knew about the board, so I thought perhaps you had one.The games above I've marked yes are those I have that I can confirm support continues. Pretty sure all CPS1 games do.Thanks for the tip.The game is not retained after power off, so I can see why this is required. Wouldn't work any other way.That wire is for auto reset, when you change games it automatically resets and starts playing the new game instead of you needing to power cycle.
3 Wonders
1941
Carrier Airwing
Final Fight - Yes
Magic Sword
Mega Twins
Mercs
Nemo
The King of Dragons
UN Squadron
FF and SF2 have famous continue screens.
Edit: I just realised you meant on the lydz kit. No idea. These multis often have modified versions of games on board but I can't see why they would remove continues. Or did you mean free play?
At least you get an answer from him. He has not replied to any of my letters so far.You knew about the board, so I thought perhaps you had one.The games above I've marked yes are those I have that I can confirm support continues. Pretty sure all CPS1 games do.Thanks for the tip.The game is not retained after power off, so I can see why this is required. Wouldn't work any other way.That wire is for auto reset, when you change games it automatically resets and starts playing the new game instead of you needing to power cycle.
3 Wonders
1941
Carrier Airwing
Final Fight - Yes
Magic Sword
Mega Twins
Mercs
Nemo
The King of Dragons
UN Squadron
I was asking if continue was something this board support. Not so much continue, but fully functioning dip switches.
I swapped the A board with a known-working board and I learned that the lydz multi does support the full function of all dip switches (though maybe dip C8 to enter TEST is ignored). When I set dip C7, continue was enabled in games that required it.
I tested the bad board with my Daimakaimura B board and learned that C dips are all messed up on it.
C7 doesn't function at all.
Daimakaimura (at least the way I like it configured) doesn't really need the C dip switches.
The seller offered me $50 back or a new board.
I thought about it for a day, and I'm trying to work out a replacement board with the seller now.
I want to receive the replacement before shipping the broken one back (I'm willing to put down a deposit).
I told the seller this and he seems to have taken the replacement option off the table.
Or we are hitting a language barrier...
Thanks.Asure' said:Start a claim in ebay and you can return the item.
He sold a defective product so your protected by Ebay and Paypal etc.
Do not let the seller give you the runaround. Good luck!
