NAC Splitfire: JAMMA streaming solution
Any updates with using th VGA to component cable yet? I am this close to running to Micro Center and getting a VGA to component cable to try it out with.
Ur better off going the route gillaxian took. Extron rgb192 and b NC to scart out. Ill help u out bro. Hit me up on discord.
The component will get the signal to your tink, but it doesn't solve any of the sync issues for most pcbs. That extron cleans the sync so it will be compatible with the tink.
I'm sure this has been asked before. How is the RGB out attenuated? There is a pot for rgb voltage but how do I achieve 220uf resistance and and 75ohm capacitance on my video out with this device?
And is my sync voltage adjusted with my RGB levels simultaneously?
I love the product. I just need to know whether I should feed it hot into a Jassifier for attenuation or not
For the folks using the Splitfire with an OSSC, what firmware version are you on and are there any other considerations?
The RGB output has 75 ohm resistors in series to match 75 ohm termination on the other side (capture card, PVM, etc). The video is DC coupled, and you should not need to consider adding capacitors or resistors.
The recommended use case is to plug it in directly to an OSSC's VGA input port and set it to AV3 with composite sync. If you want to use the SCART input, I do not have a recommended solution, as I do not keep anything SCART in my house.
If you are seeing noise, I would suspect your cabinet's power supply, your OSSC's power supply, or a grounding problem. Adding an additional video buffer, level control, and AC coupling should not help you there.
for PCB’s that don’t have wacky sync. But boards like Taito F3 still have sync issues (curling at the top).
Have you played with the new firmware on the 5X? Fiddling with the Video ADC settings (LLPLL Gain) fixed a screen curling issue I was having.. Not sure you got this fixed or not :)
Does anyone know if the Spitfire works with medium resolution (25 KHz) games? I have a friend who wants to use one with his Golden Tee Fore, but he has a medium resolution monitor in it and can’t change the dip switch to standard resolution. Thanks!
If it's JAMMA, and it has composite sync on the normal pin, then the Splitfire will buffer the video for it. Whether or not your capture setup accepts different scan rates is up to the hardware.
To be clear, if you are trying to use this to connect to a VGA monitor to replace an original monitor, that is not what this is intended for. It is not a scaler, and the signal coming out of the VGA port has the same resolution and timings as the original.
Hello guys After 2 or 3 years that I take the splitfire, finally I can try It.
Today I received the Ossc and here start the problem.
How I can output at 720p or 1080p?
I have a capture card intensity shuttle USB that accept 720p60 or 1080p24/30 or 1080i
If someone have this setup or one with an elgato hd60 and works perfectly, please share with me informations, because I can have also that capture card.
Thank you in Advance guys
it really depens on the hardware you are trying to capture.
Most stuff for me worked at x3 which on the most stuff would be 720p.
Try that one.
I capture with a similar setup (Splitfire + OSSC) but not using either of those capture cards listed. Instead I use xcapture-1 and lately Magewell USB gen 2. Both have proven to be much more reliable with many different video sources, especially retro hardware at "non-standard" spec.
Your mileage is going to vary based on a ton of different factors tho, not the least of which is your original video source (arcade PCB in this case). It's not going to be a one size fits all scenario and even with OSSC in the chain, there will be specific profiles and settings that should be considered depending on the video source.
