Ziggy Cheetos Dust
I think this must be it. It’s a huge thread.interesting. post a link here if you find it.
https://www.neo-arcadia.com/forum/viewtopic.php?t=66819
That's a very cool project but it's not the Cyberlead display, it's just a generic Pinball DMDI think this must be it. It’s a huge thread.
I see. I’ll try and find the post where I thought it was mentioned that it works with a Cyberlead display.That's a very cool project but it's not the Cyberlead display, it's just a generic Pinball DMD
if this picture is to be believedDoesn't Namco Museum and Mr. Driller support the LED display? Or did I imagine that in my head?
I don't believe so, it requires JVS support and Namco Museum is on system ND which doesn't have JVS support.Namco Museum
if you're trying to make a reproduction it will be a real challenge as there is a custom chip along with some CPLDsHello,
Has anyone already made a list of the components on the Cyber Lead I/O board? If not, could someone take clear photos of the board, zoomed in on all the components (even in several pictures), so that I can identify all the components on the board, please?
Thank you.
most likely has different code on the CPLD and Flash ROM between the two boards. chance are the CPLD label will tell you the code/revision flashedSo I would like to buy a LED DMD I/O board and populate it the same way as the lower I/O board, so I can see whether that turns the board into a “normal” I/O.
Based on what I can see from the photos and so on... they have the same code; there’s just an extra Epson chip for the DMD LED—probably to control it—and it’s not present on the I/O. In my opinion, since it’s an FPGA, there must be logic gates that determine: if a certain component is present, then execute; otherwise, use the I/O. As far as I’m concerned, they’re the same.most likely has different code on the CPLD and Flash ROM between the two boards. chance are the CPLD label will tell you the code/revision flashed
The Epson chip is only on the DMD's I/O, so I'm going to remove it to really set it up as if it were the I/O.worth experimenting with!
have you been able to find a source for the EPSOM chip?
Ok no probI have a few of these boards but they're all buried in storage, would take some time to get them out for photos.
