Ahhhhhh - ok, yeah - that is pretty slight - you won't even notice it in the game!
And yeah - the Chihiro is a little tight, but mine fit!!! Is your cab setup so its all in the back (under the monitor) or is it under the seat? Mine is under the monitor, in the back.
Yeah, the issue isn't that severe. My friend didn't even notice it until I pointed it out and he thought I was being dramatic. But I'm more concerned if it progresses into something worse that will be more noticable. Also yeah my Maxi 3 cab has the hardware under the monitor in the back.
Finally got the card reader, just gotta figure out how to wire this thing up.
Also got 2 Namco N2 motherboards in, so gonna see if replacing those will get both my N2's back up and running. I currently don't have any thermal paste ATM so I'm thinking about waiting on doing that till later in the week when I get some.
Also got the Chihiro, but only half of it. Seller said he ships it in two in order to prevent damage, The other half should be here hopefully soon.
So I swapped out one of the motherboards with one of the newer ones I got and unfortunately no luck yet. Just a black screen, doesn't show no signal this time so I guess that's a step up. But not even the USB's are flashing either. I guess this Motherboard I got was faulty? Luckily I still have another one, but I'm probably not gonna bother switching it out tonight since I gotta go to bed early tonight.
can you post some pictures of the back and side? If I am remembering right - it needs the 20v the cabinet provides, but it also needs 5volts, along with the serial connection.
Sure here you go
Just got the other half of the Chihiro and looks like those 3 caps are gonna need replacing 🥲
