Name for JVS2JAMMA board
JVSJam
JVJam
Thanks for prompt and enthusiastic input :)
Will keep the jammafier name for now, as it seems there will be confusion regardless :)
Keeping dual attenuated mono output. Attenuation of audio can be solved with so many other readily available solutions, like turning the volume down on the PCB :)
No extra connectors for upscalers, there really is no room + the upscaler I'm working on has VGA connector for input.
Cool idea. Wondering though what the SDcard slot does there?
Firmware updates + potential for options and config files for oddball setups.
PCB files sent to the manufacturer :smile:
Not sure if/when this will be available, a big hurdle is the cost/feasibility of having if manufactured - the edge connector has to be done by hand, and it as a bunch of through-hole parts. Time will tell, but personally I'm really looking forward to completing this as the available alternatives are not great imho.
Maybe a kit option that leaves the through-hole stuff up to the buyer could work?
I'd be in for at least 4. Way too useful to not have.
I agree with JVS2JAMMA being confusing, sounds to me like you're putting a JVS setup in a JAMMA cab, and others have read it the opposite. Jammafier sounds like you're turning the cab into a JAMMA setup.
In any case, eager to see where this goes!
Reactions: nem
My understanding is - a JVS cabinet with a 15/24/31hkz monitor = play nice
A JVS cabinet with a 31khz monitor = needs an upscaler like OSSC or XRGBmini to play nice with 15khz Jamma PCB..
So this will let 15khz JAMMA boards play nice on a 31 khz monitor in a JVS cabinet? Or am I confused?
it's for people who own JVS only cabs (like a Net-City) so that they can play JAMMA boards in it.
it's really just to add JVS I/O functionality to a JAMMA board.
Will this have less input delay than the Namco JAMMA adapter? It's not bad, but can be noticeable - it drops inputs occasionally too
It does not touch the video signal, at all, but handles audio and controls. With a bit of luck, I'll manage to lock JVS requests to the Vsync of the jamma pcb, which should make it very smooth.
This guy however, touches the video signal:
Getting the rev 1.2 proto boards next week :)
It's powered via USB micro, which is the reason the jammafier has a USB port so you can power it by just running a normal USB cable from jammafier to upscaler.
Power consumption of jammafier+upscaler should be about the same as the namco jvs2jamma board.
The upscaler has analog input and analog output, 30 bit color processing and zero lag. It's also optimized for arcade boards and should deal with most/all boards without any tweaking needed.
Surely it attenuates the video signal from TTL to standard "VGA" levels ?
It does not, rationale being that RGB signals attenuated to 0.7/1V while keeping the impedance of the PCB would result in a is a non-standard. Arcade PCB's have really different output impedance, and doing this would introduce yet another 'unknown'.
The subject matter is complicated enough as it is, and I would rather not complicate things by 'silently' modifying a 'known' signal into something else. Add to this the mess that is sync.
The Riverservice alters the video signal by adding 75 Ohm termination, but you will feed the signal to either an upscaler or monitor that has it's own termination - which will probably imply a 37.5 ohm load on the RGB lines which can lead to strange results.
The Namco alters the video signal by amplifying the signal, giving it 75 ohm IMPEDANCE, while only attenuating it a little - resulting in 75 ohm impedance with about 0-3V VPP RGB levels. The re-amplification adds noticeable image degradation, for 'no good reason'.
The Konami AFAIK attenuates it to VGA levels, not sure about the impdance of it - but does not touch the SYNC?
From a support and technical perspective, I concluded that it would be better to do nothing - as people will have to deal with arcade RGB/SYNC in some fashion regardless, and I would rather not alter the signal and add complexity to the video chain.
Do you have more info on this please.. what max resolution does it scale to? Is it something like the xrgb2 performance wise but easier to use? what max resolution does it support? Maybe send both units to a member here with time and knowledge to do a proper review?
It's very much a work-in-progress, and there have been a few revisions so far. It was started before the OSSC was released, but in nature it's similar in that it's a line-doubler. Making an upscaler is not for the easily discouraged :)
Main difference from the OSSC is:
- Dedicated sync processing input stage to deal with weird sync scenarios (no touch automagic)
- High impedance& Level RGB input / low impedance&level rgb input - selectable
- TTL sync / 0.7V sync - selectable
- 30 Bit analog input
- 30 bit analog output
- Different ADC than the OSSC
- Analog pass-thru, so if sync is e.g. 31k - it will pass it through without alteration
- on-screen display (WIP, haven't actually written the code for this yet)
It's really made for CRT's, as an alternative to XRGB2 and the like for 31k CRT's, but with special focus on arcade pcb's. Comparing to XRGB2, this one has a sharper image and is more stable - it CAN look a bit like mame on an LCD, but of course there will be scanlines and whatnot.
I'll probably make a thread once the new revision is assembled and development continues.
Edit: couple of CRT shots, harder to get a good photo:
"JVS Encoder"? That is what it does, right?
Or "IRKEN-JVS Encoder" :D
-ud
