Nanao 2930 - no screen with neck glow
Not sure what you mean by cab interlocks. If its the door lock switch i have that bypassed.
You just wait till the day that zip tie has loosened *ever so slightly* and then you spend an hour panicking and chasing shadows because you can't figure out why the cabinet won't turn on. I think just about every Blast owner's gone through that at one point or another.
After you do the b+ you should prob pull chassis out take good high res pics of it including bottom. Perhaps shipping damage etc or a cold solder joint.
@advans14 will do that. Good idea. Is anything other than a multimeter required to test b+?
I’m just measuring it’s voltage right? I know where the pot is, but how exactly do o i test it?
Test Point 3. Yup just a meter and voltage. Black lead on a chassis ground/ like the metal frame. Red lead on tp3 careful of your surroundings
yeah Test Point 3 is the positive probe.
Hook your Negative probe to a ground or the larger metal heat sink is usually where I clip it to.
Make sure your multi meter is set to DC voltage appropriately.
Voltage should be right on 180V DC if not very close to that.
The B+ circuit will hold its charge for about a minute or so on power down so be mindful of that! or you could get nipped
You can connect all this stuff while the cab is off if you want when you turn it on you should see the voltage on the meter come up to 180 pretty instantaneously and hold. You shouldnt see any big swings in voltages. (ie you shouldnt be seeing it go from like 180 to 185 to 176 to 180 etc etc like that kind of swinging) It should just come up and settle down at a voltage pretty quick.
Prob just unplug it and meter each component. It seems like more an excercise of boredom. but that wouldnt prevent raster i guess unless there is connection issues on the ribbon cable. I make brand new repro boards as well if you want to have an extra on hand at some point.
What are your dip settings 1 off, 2 on and 3 off?
I tried 1 and 3 off. Still no different. I guess for 15khz sw1 doesn’t matter right?
And sw3 only deals w the dsub connector? Correct?
Yeah three is for amp it will dim the pic if you use it on a jamma edge signal.
You could meter the dips. Use continuity on meter.
View: https://youtu.be/QVxwVvYyYTw
Here’s a visual rundown of what’s happening
Here’s also a pic of the neck which you couldn’t really see in the video.
I had that exact same issue in one of my blast cities. I had to send to PNL and they fixed it. He just told me it was the HV daughter pcb board and that he replaced components on it. I couldn’t get anymore info than that and not even sure if what he told me was accurate. I didn’t really try and pry more info from him cuz I was just just happy that the monitor worked again.
I cant remember if you had 2 blasts or not but if you did you can just swap the remote board and cable and rule that out right away if thats a concern?
My guess is something funny going on in the HV circuit but unless you pry around the board alot more its hard to just say its one thing.
BlinG may have a point though those HV regulating daughter boards can get cranky its possible after the recap that another component that was already tired or stressed out died? Maybe a passive like a resistor or something like a diode.
This is the same chassis you worked on in other thread? Seems like you did a burn in test. But I agree research the hv areas. There are a couple of hv shutdown and power issue threads. Also the ms2931 manual gives general guidance. Checking the power circuits etc, most likely the part numbers referenced would be off.
