NAOMI 2/Chihiro/Triforce Card Reader Emulator (Initial D3/WMMT/Mario Kart/F-ZERO AX)
Something might be wrong with my Chihiro now. I can't get it to boot any version of WMMT. The ones that allow linking just hang on the PCB ID checking screen at boot and the Export version of WMMT1 boots and gets beyond the initialization and goes through all startup screens, and then goes black. This is without the card reader even plugged up and setting wheel and card reader to off in the settings... I'm back in 512MB mode, too and it was working for me in that mode before. This is unfortunate because I just invested money into a reader.
I confirmed that OR2SP still boots and plays fine, so not sure what could be wrong.
Someone seems to have posted a similar issue with WMMT here:http://forums.arcade-museum.com/archive/index.php/t-296740.html
It might be an issue with my media board. I'll have to try unseating and re-seating it to see if that helps. Maybe clean it if that doesn't work.
That's what I was going to say. Those boards are very picky. IF you move them much, they'll give you problems...
Success!
I got WMMT2 to boot with reader installed. I bought a card, finished a race and ejected.
For the record I unseated and reseated the Chihiro media board, I adjusted voltages to 5.1 and 3.3v (I was accidentally adjusting the 3.3v pot thinking it was 5v and accidentally put it out of spec.), and unplugged the Sega force feedback connector (pretty sure I always had this plugged in before, so not sure this mattered).
I'm not sure when I'll get a chance to do extensive monitoring and testing.
I probably want to get logs of the normal processes in the game before I get into hardware analysis and comparing to the ID3 reader. I'm still curious if 24v is being down converted, but the pcb is under a metal shroud that I'll have to remove when I get a chance and go at it with a DMM.
I actually noticed something similar on the OMZ IR gun boards I've been playing with, they require 12V power but then have a +5V dc converter that's used for nearly everything on the board.
I'd suspect that since so much of it deals with analog data they do this sot that the 5V is controlled internally and more consistently as opposed to being at the whim of whatever the PSU is providing. it could be a similar situation on the card reader...
another theory would be that the FFB motor runs on 24V and the opted to draw power from that instead of the main supply... or maybe the card reader simply uses 24V solenoids instead of 12V ones.
If I recall correctly from the WMMT diagram, 12v was going to force feedback. I don't think anything else but readers got 24v.
Edited title of this thread to include Chihiro and WMMT.
Assuming I get the WMMT emulator working, is there anyone with a Triforce who could try it on the Mario Karts?
I'll post the logs for all processes for WMMT and I'll dump the rom. It may be a while before I get a chance to get to this. My wife and I just had a baby. :D
I was scrambling to get the ID3 logs and emulator in before the birth, but the WMMT reader didn't come along until too late.
I played a little WMMT2 with a card and noticed something odd. Apparently it updates the information printed on the front of the card. Is it supposed to be able to clear off the ink?
For example, I started with a car that was 320hp and upgraded it to 340hp. On my card, the 340 was printed over the 320.
I still need to wire up and record some logs.
I think it is supposed to be able to erase from what i've seen...
Interesting. As far as I've seen ID3 doesn't do that. Only new stuff in different locations is printed as you progress. Nothing gets updated.
If erasing does happen for WMMT I wonder if that's a function of the reader unit, the card or both. I'm clearly not using a correct card, so it's not a good test. I have a few WMMT cards and may eventually try it.
WMMT test menu initialization:
2016-04-22 16:26:10.576900: Chihiro
02 07 10 00 00 00 30 03 24 05 05
2016-04-22 16:26:10.592506: READER
06 02 06 10 30 30 33 03 26 02 06 10 30 30 33 03 26
2016-04-22 16:26:10.733131: Chihiro
05
2016-04-22 16:26:10.748757: READER
2016-04-22 16:26:11.592508: Chihiro
05
2016-04-22 16:26:11.608152: READER
02 06 10 30 30 30 03 25
2016-04-22 16:26:12.639386: Chihiro
02 0C 78 00 00 00 37 31 34 30 30 30 03 75
2016-04-22 16:26:12.639386: READER
06
2016-04-22 16:26:12.873760: Chihiro
05
2016-04-22 16:26:12.889386: READER
02 06 78 30 30 30 03 4D
WMMT boot initialization:
2016-04-22 16:30:17.389865: Chihiro
2016-04-22 16:30:17.405489: READER
06
2016-04-22 16:30:17.874258: Chihiro
05
2016-04-22 16:30:17.874258: READER
2016-04-22 16:31:31.405633: Chihiro
2016-04-22 16:31:31.405633: READER
06
2016-04-22 16:31:31.749403: Chihiro
05 05
2016-04-22 16:31:31.765010: READER
2016-04-22 16:31:32.749386: Chihiro
05
2016-04-22 16:31:32.765011: READER
2016-04-22 16:31:33.952533: Chihiro
02 0C 78 00 00 00 37 31 34 30 30 30 03 75 05
2016-04-22 16:31:33.968158: READER
06 02 06 78 30 30 30 03 4D
2016-04-22 16:31:34.155658: Chihiro
05
2016-04-22 16:31:34.171265: READER
WMMT - Started new game, purchased new card, finished race, ejected card:
2016-04-22 16:40:40.844227: Chihiro
02 09 33 00 00 00 32 31 30 03 0A 05 05
2016-04-22 16:40:40.859833: READER
06 02 06 33 30 30 33 03 05 02 06 33 30 30 34 03 02
2016-04-22 16:40:41.031728: Chihiro
05
2016-04-22 16:40:41.031728: READER
2016-04-22 16:40:42.141085: Chihiro
02 06 40 00 00 00 03 45 05
2016-04-22 16:40:42.156710: READER
06 02 06 40 30 30 30 03 75
2016-04-22 16:40:42.344230: Chihiro
05
2016-04-22 16:40:42.359836: READER
2016-04-22 16:40:43.812983: Chihiro
02 07 B0 00 00 00 31 03 85
2016-04-22 16:40:43.812983: READER
06
2016-04-22 16:40:44.078608: Chihiro
05 05
2016-04-22 16:40:44.094234: READER
02 06 B0 30 30 33 03 86 02 06 B0 30 30 33 03 86
2016-04-22 16:40:45.094216: Chihiro
05
2016-04-22 16:40:45.109848: READER
02 06 B0 31 30 33 03 87
2016-04-22 16:40:46.109862: Chihiro
05
2016-04-22 16:40:46.125469: READER
02 06 B0 31 30 30 03 84
2016-04-22 16:40:47.547346: Chihiro
02 07 B0 00 00 00 31 03 85 05 05
2016-04-22 16:40:47.562972: READER
06 02 06 B0 31 30 33 03 87 02 06 B0 31 30 32 03 86
2016-04-22 16:40:47.766096: Chihiro
05
2016-04-22 16:40:47.766096: READER
2016-04-22 16:40:48.750473: Chihiro
02 06 20 00 00 00 03 25
2016-04-22 16:40:48.750473: READER
06
2016-04-22 16:40:49.156724: Chihiro
05
2016-04-22 16:40:49.172368: READER
02 06 20 31 30 30 03 14
2016-04-22 16:42:10.328758: READER
06
2016-04-22 16:42:10.375652: Chihiro
02 08 7D 00 00 00 01 17 03 60 05
2016-04-22 16:42:10.594402: Chihiro
05
2016-04-22 16:42:11.828779: Chihiro
05
2016-04-22 16:42:11.844405: READER
02 06 7D 31 30 33 03 4A 02 06 7D 31 30 33 03 4A
2016-04-22 16:42:12.844389: Chihiro
05
2016-04-22 16:42:13.860016: Chihiro
05
2016-04-22 16:42:14.891286: Chihiro
05
2016-04-22 16:42:16.375645: Chihiro
05
2016-04-22 16:42:17.360022: Chihiro
05
2016-04-22 16:42:18.375649: Chihiro
05
2016-04-22 16:42:19.406920: Chihiro
05
2016-04-22 16:42:20.422546: Chihiro
05
2016-04-22 16:42:21.453798: Chihiro
05
2016-04-22 16:42:22.485050: Chihiro
05
2016-04-22 16:42:23.516303: Chihiro
05
2016-04-22 16:42:23.578803: READER
02 06 7D 31 30 30 03 49
2016-04-22 16:42:24.969411: READER
06
2016-04-22 16:42:24.985037: Chihiro
2016-04-22 16:42:25.219413: Chihiro
05
2016-04-22 16:42:26.438183: Chihiro
05
2016-04-22 16:42:26.453790: READER
2016-04-22 16:42:27.485061: Chihiro
05
2016-04-22 16:42:27.485061: READER
2016-04-22 16:42:28.516313: Chihiro
05
2016-04-22 16:42:29.547565: Chihiro
05
2016-04-22 16:42:30.563191: Chihiro
05
2016-04-22 16:42:31.578818: Chihiro
05
2016-04-22 16:42:32.594426: Chihiro
05
2016-04-22 16:42:33.625679: Chihiro
05
2016-04-22 16:42:34.625700: Chihiro
05
2016-04-22 16:42:35.641307: Chihiro
05
2016-04-22 16:42:36.656954: Chihiro
05
2016-04-22 16:42:37.688186: Chihiro
05
2016-04-22 16:42:38.735063: Chihiro
05
2016-04-22 16:42:39.063190: READER
2016-04-22 16:42:40.188191: READER
06
2016-04-22 16:42:40.250710: Chihiro
2016-04-22 16:42:40.485067: Chihiro
05
2016-04-22 16:42:41.703838: Chihiro
05
2016-04-22 16:42:41.703838: READER
2016-04-22 16:42:42.750715: Chihiro
05
2016-04-22 16:42:42.750715: READER
2016-04-22 16:42:43.781967: Chihiro
05
2016-04-22 16:42:44.813219: Chihiro
05
2016-04-22 16:42:45.828846: Chihiro
05
2016-04-22 16:42:46.828848: Chihiro
05
2016-04-22 16:42:47.860100: Chihiro
05
2016-04-22 16:42:48.875709: Chihiro
05
2016-04-22 16:42:49.891354: Chihiro
05
2016-04-22 16:42:50.906981: Chihiro
05
2016-04-22 16:42:51.953839: Chihiro
05
2016-04-22 16:42:52.922591: READER
2016-04-22 16:42:53.406986: READER
06
2016-04-22 16:42:53.453843: Chihiro
2016-04-22 16:42:53.688237: Chihiro
05
2016-04-22 16:42:54.906970: Chihiro
05
2016-04-22 16:42:54.922609: READER
2016-04-22 16:42:55.906972: Chihiro
05
2016-04-22 16:42:55.922598: READER
2016-04-22 16:42:56.922599: Chihiro
05
2016-04-22 16:42:57.938244: Chihiro
05
2016-04-22 16:42:58.969497: Chihiro
05
2016-04-22 16:43:00.000749: Chihiro
05
2016-04-22 16:43:01.047626: Chihiro
05
2016-04-22 16:43:02.078860: Chihiro
05
2016-04-22 16:43:03.110112: Chihiro
05
2016-04-22 16:43:04.125738: Chihiro
05
2016-04-22 16:43:05.141365: Chihiro
05
2016-04-22 16:43:06.141369: Chihiro
05
2016-04-22 16:43:06.203867: READER
2016-04-22 16:43:07.578889: READER
06
2016-04-22 16:43:07.594495: Chihiro
2016-04-22 16:43:07.813246: Chihiro
05
2016-04-22 16:43:09.047641: Chihiro
05
2016-04-22 16:43:09.063267: READER
2016-04-22 16:43:10.078894: Chihiro
05
2016-04-22 16:43:10.094500: READER
2016-04-22 16:43:11.094502: Chihiro
05
2016-04-22 16:43:12.125772: Chihiro
05
2016-04-22 16:43:13.157025: Chihiro
05
2016-04-22 16:43:14.157027: Chihiro
05
2016-04-22 16:43:15.188278: Chihiro
05
2016-04-22 16:43:16.203888: Chihiro
05
2016-04-22 16:43:17.250783: Chihiro
05
2016-04-22 16:43:18.266410: Chihiro
05
2016-04-22 16:43:19.282019: Chihiro
05
2016-04-22 16:43:20.313289: Chihiro
05
2016-04-22 16:43:20.328914: READER
2016-04-22 16:45:33.422924: READER
06 06 02 06 53 31 30 33 03 64
2016-04-22 16:45:33.501049: Chihiro
02 4E 53 00 00 00 30 31 30 51 76 00 00 7F 7E 82 90 FF 0A 09 17 00 00 A0 21 00 00 00 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 51 00 00 00 00 00 00 00 01 00 00 00 D6 05 00 00 02 03 34 02 4E 53 00 00 00 30 31 30 51 76 00 00 7F 7E 82 90 FF 0A 09 17 00 00 A0 21 00 00 00 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 51 00 00 00 00 00 00 00 01 00 00 00 D6 05 00 00 02 03 34 05 05 05
2016-04-22 16:45:34.485425: Chihiro
05
2016-04-22 16:45:35.532284: Chihiro
05
2016-04-22 16:45:35.532284: READER
02 06 53 31 30 30 03 67
2016-04-22 16:45:37.188537: READER
06
2016-04-22 16:45:37.251056: Chihiro
02 9B 7C 00 00 00 30 30 01 11 82 69 82 68 82 6C 82 50 0D 4E 49 53 53 41 4E 20 53 4B 59 4C 49 4E 45 0D 47 54 2D 52 20 5B 42 43 4E 52 33 33 5D 0D 11 4E 20 43 6C 61 73 73 0D 11 82 51 82 57 82 4F 82 67 82 6F 81 5E 14 42 0D 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0D 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0D 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0D 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 0D 20 55 52 59 39 42 35 59 57 32 38 4E 35 54 53 34 03 E2 05
2016-04-22 16:45:37.329163: READER
02 06 7C 31 30 33 03 4B
2016-04-22 16:45:37.376057: Chihiro
05
2016-04-22 16:45:37.485432: Chihiro
05
2016-04-22 16:45:37.985433: Chihiro
05
2016-04-22 16:45:38.626059: Chihiro
05
2016-04-22 16:45:39.063560: READER
2016-04-22 16:45:39.235417: Chihiro
05
2016-04-22 16:45:39.251042: READER
2016-04-22 16:45:39.860436: Chihiro
05
2016-04-22 16:45:40.501063: Chihiro
05
2016-04-22 16:45:41.110420: Chihiro
05
2016-04-22 16:45:41.735421: Chihiro
05
2016-04-22 16:45:42.360441: Chihiro
05
2016-04-22 16:45:43.001068: Chihiro
05
2016-04-22 16:45:43.626050: Chihiro
05
2016-04-22 16:45:43.641675: READER
02 06 7C 31 30 30 03 48
2016-04-22 16:45:44.751053: READER
06 02 06 80 31 30 33 03 B7
2016-04-22 16:45:44.813552: Chihiro
02 06 80 00 00 00 03 85 05 05
2016-04-22 16:45:44.969806: Chihiro
05
2016-04-22 16:45:44.985430: READER
2016-04-22 16:45:45.157303: Chihiro
05
2016-04-22 16:45:45.172947: READER
02 06 80 34 30 30 03 B1
2016-04-22 16:45:45.438573: Chihiro
05
2016-04-22 16:45:45.454178: READER
2016-04-22 16:45:45.782304: Chihiro
05
2016-04-22 16:45:45.797930: READER
2016-04-22 16:45:46.110449: Chihiro
05
2016-04-22 16:45:46.126055: READER
2016-04-22 16:45:46.438574: Chihiro
05
2016-04-22 16:45:46.454181: READER
2016-04-22 16:45:46.782325: Chihiro
05
2016-04-22 16:45:46.782325: READER
2016-04-22 16:45:47.110451: Chihiro
05
2016-04-22 16:45:47.126071: READER
2016-04-22 16:45:47.422932: Chihiro
05
2016-04-22 16:45:47.438558: READER
2016-04-22 16:45:47.719827: Chihiro
05
2016-04-22 16:45:47.735452: READER
2016-04-22 16:45:48.063578: Chihiro
05
2016-04-22 16:45:48.079203: READER
2016-04-22 16:45:48.376059: Chihiro
05
2016-04-22 16:45:48.391703: READER
02 06 80 30 30 30 03 B5
WMMT - Started game, inserted existing card, won race, tuned to increase HP, ejected card:
PART 1:
2016-04-22 16:49:21.313976: Chihiro
2016-04-22 16:49:21.329615: READER
2016-04-22 16:49:21.485870: Chihiro
05
2016-04-22 16:49:21.501477: READER
2016-04-22 16:49:22.751498: Chihiro
05
2016-04-22 16:49:22.751498: READER
2016-04-22 16:49:24.282731: Chihiro
05
2016-04-22 16:49:24.298370: READER
2016-04-22 16:49:25.829610: Chihiro
05
2016-04-22 16:49:25.829610: READER
2016-04-22 16:49:27.345238: Chihiro
05
2016-04-22 16:49:27.360863: READER
2016-04-22 16:49:28.892116: Chihiro
05
2016-04-22 16:49:28.892116: READER
FF
2016-04-22 16:49:30.423388: Chihiro
05
2016-04-22 16:49:30.439013: READER
02 06 33 31 30 30 03 07
2016-04-22 16:49:30.923389: READER
06 02 06 33 31 30 33 03 04
2016-04-22 16:49:30.954639: Chihiro
02 09 33 00 00 00 30 31 30 03 08 05 05
2016-04-22 16:49:31.126514: Chihiro
05
2016-04-22 16:49:31.142120: READER
2016-04-22 16:49:31.970266: Chihiro
05
2016-04-22 16:49:32.048391: READER
02 4B 33 31 30 30 51 76 00 00 7F 7E 82 90 FF 0A 09 17 00 00 A0 21 00 00 00 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 51 00 00 00 00 00 00 00 01 00 00 00 D6 05 00 00 02 03 51
2016-04-22 16:49:34.189020: Chihiro
2016-04-22 16:49:34.189020: READER
06
2016-04-22 16:49:34.439001: Chihiro
05
2016-04-22 16:49:35.532756: Chihiro
05
2016-04-22 16:49:35.892148: Chihiro
05
2016-04-22 16:49:35.907755: READER
2016-04-22 16:49:36.907775: Chihiro
05
2016-04-22 16:49:37.939027: Chihiro
05
2016-04-22 16:49:38.970261: Chihiro
05
2016-04-22 16:49:40.017137: Chihiro
05
2016-04-22 16:49:41.048389: Chihiro
05
2016-04-22 16:49:42.079660: Chihiro
05
2016-04-22 16:49:43.095286: Chihiro
05
2016-04-22 16:49:44.142159: Chihiro
05
2016-04-22 16:49:45.157773: Chihiro
05
2016-04-22 16:49:45.173398: READER
2016-04-22 16:49:46.204649: Chihiro
05
2016-04-22 16:49:46.610901: READER
2016-04-22 16:50:13.610972: READER
06
2016-04-22 16:50:13.657829: Chihiro
2016-04-22 16:50:13.892205: Chihiro
05
2016-04-22 16:50:15.110956: Chihiro
05
2016-04-22 16:50:15.126581: READER
2016-04-22 16:50:16.126602: Chihiro
05
2016-04-22 16:50:16.142209: READER
2016-04-22 16:50:17.157854: Chihiro
05
2016-04-22 16:50:18.189106: Chihiro
05
2016-04-22 16:50:19.689109: Chihiro
05
2016-04-22 16:50:20.689092: Chihiro
05
2016-04-22 16:50:21.720362: Chihiro
05
2016-04-22 16:50:22.767221: Chihiro
05
2016-04-22 16:50:23.798474: Chihiro
05
2016-04-22 16:50:24.829743: Chihiro
05
2016-04-22 16:50:24.845349: READER
2016-04-22 16:50:25.860996: Chihiro
05
2016-04-22 16:50:26.501622: READER
2016-04-22 16:50:27.126623: READER
06
2016-04-22 16:50:27.157855: Chihiro
2016-04-22 16:50:27.376624: Chihiro
05
2016-04-22 16:50:28.595376: Chihiro
05
2016-04-22 16:50:28.610983: READER
2016-04-22 16:50:28.829752: Chihiro
05
2016-04-22 16:50:28.845377: READER
2016-04-22 16:50:29.626610: Chihiro
05
2016-04-22 16:50:29.626610: READER
2016-04-22 16:50:30.657880: Chihiro
05
2016-04-22 16:50:31.673507: Chihiro
05
2016-04-22 16:50:32.704741: Chihiro
05
2016-04-22 16:50:33.735992: Chihiro
05
2016-04-22 16:50:34.767245: Chihiro
05
2016-04-22 16:50:35.814121: Chihiro
05
2016-04-22 16:50:36.861017: Chihiro
05
2016-04-22 16:50:37.876627: Chihiro
05
2016-04-22 16:50:38.907896: Chihiro
05
2016-04-22 16:50:39.923504: Chihiro
05
2016-04-22 16:50:40.017255: READER
2016-04-22 16:50:41.392257: READER
06
2016-04-22 16:50:41.439133: Chihiro
2016-04-22 16:50:41.657901: Chihiro
05
2016-04-22 16:50:42.892279: Chihiro
05
2016-04-22 16:50:42.907905: READER
2016-04-22 16:50:43.907906: Chihiro
05
2016-04-22 16:50:43.923533: READER
2016-04-22 16:50:44.923514: Chihiro
05
2016-04-22 16:50:45.954766: Chihiro
05
2016-04-22 16:50:47.001644: Chihiro
05
2016-04-22 16:50:48.048539: Chihiro
05
2016-04-22 16:50:49.064149: Chihiro
05
2016-04-22 16:50:50.111024: Chihiro
05
2016-04-22 16:50:51.142295: Chihiro
05
2016-04-22 16:50:52.173547: Chihiro
05
2016-04-22 16:50:53.189175: Chihiro
05
2016-04-22 16:50:54.251660: Chihiro
05
2016-04-22 16:50:54.251660: READER
02 06 7D 31 30 30 03 49 02 06 7D 31 30 30 03 49
2016-04-22 16:50:55.704785: READER
06
2016-04-22 16:50:55.751661: Chihiro
2016-04-22 16:50:55.970411: Chihiro
05
2016-04-22 16:50:57.204807: Chihiro
05
2016-04-22 16:50:57.220421: READER
2016-04-22 16:50:58.236059: Chihiro
05
