E
Euphoria
Hi :
Where can I find the information needed to run these games? And the Naomi ones?
I have a Naomi 2 pcb, 256mb dim board rev 3.? and gdrom.
Regards
Euphoria :D
xodaraP
Gold Coast, Australia
E
Euphoria
Hi ;
Confirmed netdimm 256 module ver 3.17 and naomi mb is a version b. bought a gdrom also. Now i realise i cant connect the gdrom to the netdimm module.
Regards
Euphoria
xodaraP
Fairly sure you can, the NetDIMM is the same as a regular DIMM board with an Ethernet port on it, but if you can netboot you don't really need the GD ROM anyway
To net boot 3.17 is fine, but I would upgrade it to 4.01 anyway (you upgrade via Ethernet) to ensure everything will run properly.
You will also need to get yourself a Raspberry Pi, a screen and a microsd card loaded with Pi Force Tools, as well as a Zero PIC (I can help if you're in Australia) if you want to netboot games
Alternatively you need a CF reader with the correct connector and a Zero PIC set up for CF cards (again if you're in Australia I can help there)
stj
England
ones without the scsi-LOOKING IDE connector and called satellite dimm's,
there is probably a lot of those in japan from horse racing and mahjong games.
but they should be rare in the west - unless someone is importing lots of them.
