DorianGray
I am a longtime fan of the Street Fighter franchise and have spent years chasing the "arcade perfect" setup. Recently I learned about the CPS-3 board and Supergun combo. I have done a bit of research and it seems that I will need a CPS-3 board with a Street Fighter 3 cart, the CD-ROM and disc and a Supergun to make it all work. It also sounds like there are a few options/variations, some of which are better than others. Below is a list of what seems to be the most ideal setup.
- A modded cart, one of the mods removes the need for a battery and the other mod is the Darksoft mod (I know this included 6 games, but I am not sure what else it does).
- Using an SD card/reader loaded with the software (from the disc) is also the preferred mod from what I gather (as opposed to the cd rom).
- A modded board that removes the need for a battery on the board
- Recapped board (do some capacitors need to be replaced over time?)
- Enough ram to run the games, I have seen 1x64Mb+2x128mb being the ideal amount (are these the "SIMMS"?) Are there different or better brands of ram?
- A Supergun (is there an ideal variant that will work best with the CPS-3 setup?)
- I currently have fight sticks with the Brooks Universal Board, will they be compatible with the Supergun/CPS-3 setup?
- What kind of video outputs should I be looking for on a Supergun for arcade perfect performance, I was planning on hooking it up to an old CRT but I'd like the option to switch to something more modern
