the Goat
You need to change the DIP switches on the physical CPS1 board.If you need to change DIP switches, can this be done in software or do you need to remove the multi to get at them?
Right so you need to dismantle the multi to change them?You need to change the DIP switches on the physical CPS1 board.
lcd selectorHow can we choose the game on this system : directly on tv screen or on pcb, using buttons?
Thx
I think you can reach them without disassembling anything. Use a small screwdriver or something.Right so you need to dismantle the multi to change them?
Or at least take off the filter board and poke at them with a toothpick.
Same, I have a long and a short but my short is cutting off character's legs in SFII. Probably easy to troubleshoot but a pain due to the CPS1 stacked design and I'll have to shell out for something like this https://www.arcaniac.com/products/capcom-cps1-a-board-diagnostic-helper-repair-toolIt’s a shame the long A boards aren’t supported, I don’t recall this was mentioned earlier in the threads, maybe it was and I missed it.
You don’t need to be put down on a list anymore.Put me down for 1 also. Thank you
Thank youYou don’t need to be put down on a list anymore.
Just preorder from here: https://highscoresave.com/
Nice. Makes the wait more worth it. I'm still working on wire routing and everything else in my cabinet so have plenty of time to adjust based upon what goodies come out.You can remove the filterboard to change the dips but I'm also designed some option boards that can be installed on the motherboard to relocate the dips. I'll give more info after testing them.
The list is l33t multi-game history tho. Gotta get your name on the wall for the documentary in 20 yearsYou don’t need to be put down on a list anymore.
looking good, fellas! Can't wait for mine to come to me!
Can't wait to see that.You can remove the filterboard to change the dips but I'm also designed some option boards that can be installed on the motherboard to relocate the dips. I'll give more info after testing them.
Your IC# got your preorder approved for the first 2 weeks of preorders. Then orders opened up for everyone.There is something I don't really understand : I've just been to saveyourgames.it and placed my (pre)order. My interest check number has never been asked/requested/demanded...
I guess it's not necessary anymore? Has it ever been?
