A
Apocalypse
Nope.I'm interested in this if it would use PSRAM, or have every game flashed and banked from the start.
You're right this isn't in the plans at the moment.I would NOT expect an on-screen menu.
I'm all about the LCD selector.^ excellent. I like the LCD process.
I have a Dynamo HS5 case, what I did is put a switch above the left circle hole wired to test. After I open the coin door to access the LCD. Then after the game loads, I hit the test switch if I want to go to the operator menu. No opening the control panel to access the CPS2 moboI'm opening my cab with CPS2 to get into the service menu to turn off demo sounds and put on free play anyways, it's never bothered me to use the LCD screen. No hacky "hold this button and this joystick position for 3 seconds" nonsense like the OSD has. But I really don't have strong feelings about it either way, I'm not one to switch games every 5 minutes.
Makes sense to me!An SD card is fine. I just don't want it to be literally flashing every time a game is chosen.Out of curiosity, why this rather than the usual SD card route?I'm interested in this if it would use PSRAM, or have every game flashed and banked from the start.
My CPS2 Darksoft is in linked Astro Cities, it's really no big deal to open the door, mess with LCD, wait for load, and then press button on the case. When I load a game it tends to stay on for a while though, everyone's habits may be different.I have a Dynamo HS5 case, what I did is put a switch above the left circle hole wired to test. After I open the coin door to access the LCD. Then after the game loads, I hit the test switch if I want to go to the operator menu. No opening the control panel to access the CPS2 moboI'm opening my cab with CPS2 to get into the service menu to turn off demo sounds and put on free play anyways, it's never bothered me to use the LCD screen. No hacky "hold this button and this joystick position for 3 seconds" nonsense like the OSD has. But I really don't have strong feelings about it either way, I'm not one to switch games every 5 minutes.
I picked up a board last week, so I'm in for one.
interested in one too! thanks
Ok guys, who's interested in there being a proper CPS1 multi made that is accessible for us to purchase???
Me?: Yes
How many would I buy?: 1
I will take one too.
All added to want list.There's so many great games on CPS1. May as well put me down for one too
I just assumed a SF2:CE B21 C-board would be required, for this reason and for ease of ROM patching (I think every set has already been converted to use it sucessfully).I would think Street Fighter 2 Boards would best simply because the Kick header is located on the C-Board and you wont have that with other donors... unless the multi will also be including a kick header itself.
If the game in question required more eeproms/memory I could see that.he’s charging more based on title
