cynistar
New User
Okay. I might have a problem with my stick wiring then. The joystick movement is recognized in the boot menu, but not the buttons.Yes!
I'm trying to wrap my mind around how I would design a case. The problem is, there are no screw holes to hold it down or notches to brace against. If I go with my normal design, trying to plug in the USB would shove the board out the other side. Maybe I could design something where the two halves clamp down on the board using four screws? I don't know what the button does, but I assume users need access to it. I don't have one, so it's hard to verify any of this.Anyone working on a 3D Printed case for these yet?
Ideally the board could be designed to fit in the molded case the undamned adapters use (and somebody finds the source for those).I'm trying to wrap my mind around how I would design a case. The problem is, there are no screw holes to hold it down or notches to brace against. If I go with my normal design, trying to plug in the USB would shove the board out the other side. Maybe I could design something where the two halves clamp down on the board using four screws? I don't know what the button does, but I assume users need access to it. I don't have one, so it's hard to verify any of this.
If you look well the PCB, there's holes for screws.I'm trying to wrap my mind around how I would design a case. The problem is, there are no screw holes to hold it down or notches to brace against. If I go with my normal design, trying to plug in the USB would shove the board out the other side. Maybe I could design something where the two halves clamp down on the board using four screws? I don't know what the button does, but I assume users need access to it. I don't have one, so it's hard to verify any of this.
You can design your own if you like, it's open source.Ideally the board could be designed to fit in the molded case the undamned adapters use (and somebody finds the source for those).
https://paradisearcadeshop.com/products/undamned-db15-usb-decoder
Actually we are on BATCH 6 pre-order.I was looking for just that! How can I enter Batch 5? I sent a private message to @Raph_friend is this the correct procedure?
This one is absolutely a labor of love, huge thanks to @Raph_friend and the team for releasing the helper board and code.Thanks for your effort to try make your units, @hatmoose . It's really tough time for us that work with hardware production.
Thanks! I’ve reached the local maxima of Sketchup Make and am stuck there. F360 is my next learning journey.You can try Fusion 360 for more precise results.
