snakeGrave
1)Pulled U8 and left U9 in and there was no noticeable difference in audio, music was still rad and voices/some effects remained garbled.
2)pulled U9 as well as U9 and audio was mostly just fart like noises. No solid music or effects really
3) I then put the old U8 into the U9 position while leaving the U8 position unpopulated: same result as in situation 1, this seems to rule out that I have a bad LS74257 in U8 or U9 positions?
4) U8 and U9 populated with switched chips from my starting point: same as situation 1, 3 and my starting point.
I'm scratching my head here. Maybe I've got a messed up PGM the only other game I have is some crummy fighter that I bought so that I could scope out the case. I thought everything played right with it but I could be wrong, I'm gonna pull it up on MAME and compare.
In this link are some images of my assembled boards
https://imgur.com/a/MfHqt5O
EDIT: damnit I'm pretty sure I have a bunk PGM some of the voices are all squeaky and weird in my copy of killing blade compared to the emulated version
EDIT2: Pretty sure it was my dip switch settings on my PGM I guess they were all off and for some reason these things have an impact on audio? Everything sounds good after setting switches 2,3, and 4 to on
