@Derick2k are you using the auto reset feature with PiForce Web or the regular LCD screen?That’s as far as I have got... and it doesn’t work with the web solution. Python code needs some revisiting...I just need to figure out the relay bit next!
I’ll send it your way in a fewCan you send me Also?
Nice! Do you have any details of the fix? We should roll those straight into the PiForce Web code on Git....PiForceWeb. Yup, the reset code was not working on any of the builds I tried so I fixed that, working now![]()
I can send you a link to the image I sent DJsheep, it’s made for a 32gb card since all the N1,N2, AW game Roma should fit on there.
I just wrote the reset code into 2 files, I forgot the name of the files/locations. I'll dig into what I did later on, but you will probably get to it before I do from the image I sent ya.Nice! Do you have any details of the fix? We should roll those straight into the PiForce Web code on Git....PiForceWeb. Yup, the reset code was not working on any of the builds I tried so I fixed that, working now![]()
Sounds goodHey @Derick2k, grabbed the 64GB SD card out of the GoPro and wrote the image you provided successfully using Etcher on the Mac. Loaded and renamed a few ROMS and all works perfectly.
One last question, is it possible to still have the LCD screen active in conjunction with the Web Booting?
. I might try it later on.Is the fix as simple as putting lines of code in a config file? Or does the code have to be recompiled?PiForceWeb. Yup, the reset code was not working on any of the builds I tried so I fixed that, working now![]()
You should be good!Also, I used chunksin's version of the PiForceWeb to set this image up which works quite nicely.
I thought the same as well. Maybe it’s the different versions/forks?! Not sure. I tried a different versions of piforceweb, and I know I could not get the reset mod to work because they were missing the code. So if added on the image I sent you.Still having no luck getting the LCD to work simultaneously with the Web Boot. If anyone has any ideas, please let me know. I thought I read on here it should work automatically like that?
Can I have a link too? I've been just sshing into my desktop on my phone to send roms over lmao.PiForceWeb. Yup, the reset code was not working on any of the builds I tried so I fixed that, working now![]()
I can send you a link to the image I sent DJsheep, it’s made for a 32gb card since all the N1,N2, AW game roms should fit on there.
