Like dreambtw if anybody is wondering what a room full of cute looks like heres a video
View: https://youtu.be/6DkhtfOg6i0
I found that monitor thread.Gotta find that info
Ah yes, I was able to buy that LCD brand new.I found that monitor thread.
At the time. the ASUS VB199T-P 19" LCD was readily on ebay.
@Epyc shared his pics running 4x integer.
Finally got my Mini Cute done and up and running. Owlnonymous tracked down two freshly capped K7000 chassis with some burn free tubes and I am super impressed with how everything fits and looks. We are going to knock out Owl's Mini Cute here in the next few weeks. Thanks to Hursit, Cereth, and all the people behind the scenes that helped make this happened, this was quite the project.
To my knowledge, they came with the cabinet, and I'm sure Hursit got it as close as humanly possible.that does look nice. can i ask where you got the speaker arts from and is it exactly the same size as the original?
it was really FUN to watch unboxing and assembly video.LIVE NOW with an Capcom Cute repo unboxing! - https://twitch.tv/owlnonymous
What switcher?Tried powering mine up, I'm getting 120 to the switcher, but no dc voltage back out. Any suggestions? Everything I've checked seems fine, wondering if it's a dead switcher?
The switching psu that came with the kit with buttons. I have ac voltage in, but no +5, +12, etc. I tried it with my working board plugged in, also nothing.What switcher?
Do you mean you have no DC output on the power supply (PSU)?
If that is the issue, certain Mean-Well power supplies have a minimum load requirement to turn on.
Did you switch the internal switch on MW from 220 default to 120volts?Tried powering mine up, I'm getting 120 to the switcher, but no dc voltage back out. Any suggestions? Everything I've checked seems fine, wondering if it's a dead switcher?
Yeah, that was it. I thought I had done that prior during building, so I didn't even double check. Derp. Thanks for the tip! Board powered up, but now not getting anything on the monitor. Just need to figure that out and should be good.Did you switch the internal switch on MW from 220 default to 120volts?
Was gonna add to check the 115/230v switchYeah, that was it. I thought I had done that prior during building, so I didn't even double check. Derp. Thanks for the tip! Board powered up, but now not getting anything on the monitor. Just need to figure that out and should be good.
Just to double check, black on monitor connections goes next to rgb, the white is the sync line?
Yes ground black. Sync white.Yeah, that was it. I thought I had done that prior during building, so I didn't even double check. Derp. Thanks for the tip! Board powered up, but now not getting anything on the monitor. Just need to figure that out and should be good.
Ask and you shall receive lol..I wanna see someone actually using this thing. Then I wanna see someone playing it 2 player.
I wanna see two grown ass men playing on this thing.
