I used the command line tool on Mac initially. It seemed to work, but when I hooked it up to a Windows PC, one of the settings that I'm pretty I had set via the Mac software was loading incorrectly on the Windows machine.
First download the utility:
scsi2sd-util.dmg
And the latest firmware:
firmware_bundle-v4.6.00.scsi2sd
Steps to update firmware:
1. Mount the disk image.
2. Copy the utility from the disk image to your Desktop
3. Launch the Terminal.app application and navigate to your Desktop:
cd ~/Desktop
4. Once in the Desktop, launch the "scsi2sd-util" application:
./scsi2sd-util
5. You'll be presented with the UI as documented in this thread earlier, see screenshot.
6. Select File --> Upgrade Firmware... from the Menu bar, see screenshot.
7. Point to the firmware file you downloaded earlier.
Steps to set up board as a CD-ROM:
1. From the General settings tab, make sure "Enable Parity" is checked.
2. From the "Device 1" tab, change the "SCSI ID" to a value of 1
3. Device type should be "CDROM"
4. Device size should be set to 700 MB.
5. Click Save to Device button.
Once that is done, I would disconnect and reconnect the board, and click the "Load from Device" button. The settings you had set previously are read and should display correctly. This is the part that didn't work for me on the Mac, but did on Windows.
Preparing the SD card (Optional):
1. Download and install the SD Formatter:
SDFormatter_4.00B.pkg
2. Insert the SD card in your Mac and launch the SD Formatter.
3. If the SD card is still formatted as FAT32, select Quick Format, no need to name the card, click the Format button.
Create the ISO:
1. Mount your source optical disc on your Mac.
2. Launch Terminal.app and enter the following command:
hdiutil makehybrid -iso -joliet -o image.iso /path/to/source
(hdiutil is the name of the command,
makehybrid is the action,
-iso is the filesystem,
-joilet adds the Joliet support to the ISO,
-o is the output option,
image.iso is the output file,
/path/to/source would be your source disc; usually mounted to /Volumes/)
Write ISO to SD card:
1. Still in Terminal.app, type:
diskutil list
2. This will return a list of disks currently attached to your Mac.
3. Look for the disk information that pertains to your SD card, you want the Identifier that pertains to the partition for your SD card, such as
/dev/disk4s2
4. Unmount this volume via the commandline and not be ejecting the SD card,
diskutil unmount /dev/disk4s2
5. This unmounts the file system which allows us to write the ISO image to this volume, which we do by typing:
sudo dd if=/path/to/image.iso of=/dev/rdisk4s2 bs=1m
sudo to elevate permissions,
dd is the actual command,
if=/path/to/image.iso is the input file,
of=/dev/rdisk4s2 is the output file. Here we add a letter
r before the disk identifier to allow for raw block I/O and
bs=1m is the block size. These last two operands are optional but speed up the writing to the SD card.)
Once dd is done, you will not be able to read or write to the card on your Mac unless you reformat it. But you should now be able to insert it into your SCSI2SD board and use it on your CPS3 setup.
Hope this helps.
