Platform: BlueSCSI (Pico1)
FW Version: 2025.08.02-rel Aug 2 2025 16:25:01
Flash chip size: 2048 kB
I2C Supported
=== SD Card Info ===
SD card detected, exFAT volume size: 15189 MB
SD Name: SL16G, MID: 0x03, OID: 0x53 0x44
Speed grade set to reclocking system
Initial Clock set to 133MHz
Reclocking the MCU to 200MHz
Setting the SDIO clock to 40MHz
After reclocking, system reports clock set to 200MHz
======== Reinitializing BlueSCSI after reclock ========
=== Global Config ===
bluescsi.ini not found, using defaults
=== Finding images ===
=== Finding images in / ===
== Opening /CD10_2048-WZv1.iso for ID:1 LUN:0
---- Configuring as CD-ROM drive
== Platform supports ROM drive up to 1465 kB
=== Configured SCSI Devices ===
ID: 1, BlockSize: 2048, Type: Optical, Quirks: Apple, Size: 45584kB, Removable
Clock set to: 200MHz
Initialization complete!
INFO: Pico Voltage: 3.217V.
scsi_accel_rp2040_finishRead timeout
SCSI DMA state: READ
Current buffer: 0x00000006/0x00000006, next 0x00000000 bytes
SyncOffset: 0 SyncPeriod 0
PIO Parity SM: tx_fifo 0, rx_fifo 0, pc 6, instr 0x000060C8
PIO Data SM: tx_fifo 4, rx_fifo 0, pc 17, instr 0x0000201A
PIO Sync SM: tx_fifo 0, rx_fifo 0, pc 0, instr 0x00000000
DMA CH A: ctrl: 0x0102B021 count: 0x00000006
DMA CH B: ctrl: 0x001FC007 count: 0x00000000
DMA CH C: ctrl: 0x0103400B count: 0x00000001
DMA CH D: ctrl: 0x01014809 count: 0x00000001
GPIO states: 0x1773F87D
WATCHDOG TIMEOUT, attempting bus reset
Platform: BlueSCSI
GPIO states: out 0x1633FEFF oe 0x0A5C8FFF in 0x1733FAFF
scsiDev.cdb: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
scsiDev.phase: 6
SCSI DMA state: IDLE
Current buffer: 0x00000000/0x00000000, next 0x00000000 bytes
PIO Data SM: tx_fifo 0, rx_fifo 0, pc 14, instr 0x000090A0
DMA CH A: ctrl: 0x0002B
