A quick test to convert the Verilog code for the PCM into discrete logic chips. I am not sure if I've got all inverters correct, you can probably use smaller latches, and I'm sure you could optimise out the counter... I'll have to double-check everything against the timing diagrams.
This is still going to take quite some space compared to a small CPLD.
The talk about the STM32 makes me think if you could run an OGG decoder on a microcontroller and then stream the result over an ADPCM channel to the NeoGeo. You'd ignore the address and just write to the data bus. Though probably only interesting for homebrew...
