Mrhide
Legendary
Correct for working with dvr111dbk
Ok, I'll buy it. I have 246b too so i hope it will workCorrect for working with dvr111dbk
I’m glad you finally got to try it out bro!Works perfect on them 100 doller 246c's from alliexpress
What I/O are you using? I was able to navigate the test menu just fine using both my original Namco FCA pcb and the NA-JV2 I/O
Time crisis 3 and soul caliber 3 do NOT work with that drive thoughCorrect for working with dvr111dbk
I find that odd considering that every drive I tried worked flawlessly with SC3soul caliber 3 do NOT work with that drive though
it freeze ... and black screen. Time crisis 3 freee-freee-frreee-freee-freee-ze as well.I find that odd considering that every drive I tried worked flawlessly with SC3
Do you know when this error pops up? Like around specific hour? I did run RRV for at least 2 hours and it ran just fineDoes this eliminate FF? What about intermittent in-game ERROR 7 for those of us still running the dedicated arcade cabinet on route?
ERROR 7 pops up even when It's not pots, bad wiring, bad psu, bad motor, bad motor board, or bad 246A.
The error occurs when the pot sends a value to the logic which it does not anticipate. Much like how a triforce with reset if you send it a pot signal from steering it does not allow (full 360 motion for example). New pots did not address it. Usually only when kids (99% of the people who play it) are too aggressive with the wheel does it pop up. It's at a non-supervised location right now and I've just sold the machine to a friend who runs a freeplay supervised arcade so he'll be able to power cycle it or w/e it needs should that error pop up in the future, instead of it being out of service for a full day because of error 7.Do you know when this error pops up? Like around specific hour? I did run RRV for at least 2 hours and it ran just fine
Still doesn't work for me! Even with the same driveThis one was the issue:
First lg drive, not working
gave this error:
Then this one
Gave me this!
Thanks again! This was fun!
(And no, the force feedback does not work but i still can’t navigate the test menu…)
Everything works now!Still doesn't work for me! Even with the same drive
you need the 246/256 multi and you write that dongle to it. that's all. there's no "patching"... the dongle file is the complete "patch".Hello, how do I apply the patch?
hello link do not work are there any other way to download the file? thnaks a lotToday I'll be releasing the force feedback patch for Ridge Racer V!
This game requires several components to run but thanks to this patch you can now play it with just your I/O board!
Here are some screenshots! :
And a video of the game in action! :
Screenshots and video are made by @Franco23444.
Download Here!
