Veritas978
Okay, do you have your cabinet controls wired to a Jamma connection and the Dreamcast video plugging straight to the monitor?
This definitely won’t have any compatibility with VMU.Friend how does the VMU saves work with this adapter?
I hope to be able to use the VMU save on another joystick port.This definitely won’t have any compatibility with VMU.
Then a fishing rod would still work with cable running through coin slotWell this thing plugs into your Dreamcast so you could just plug in a Dreamcast controller with a VMU into port 3 and 4
Very curious to see this in action.I just received my adapter here in Brazil, I will test and post the result here.
What I was in doubt was about the VMU but to my surprise it already has a save VMU integrated in the adapter.![]()
Yes I am using a GDEMU on my DC.Very curious to see this in action.
Is that a gdemu in your DC?
there are 2 other sites I found: Mikes arcade and PCBjunkie, not sure they have stockIn case anyone is looking for an easy way to adapt this to work in a JAMMA cab, I'd recommend a CHAMMA to JAMMA adapter, like the one JNX sells:
https://www.ebay.com/itm/155224211926
Shows OOS on ebay, but I think he is a member here and you could try to send a message and see if he has anymore available.
