In case anyone is looking for an easy way to adapt this to work in a JAMMA cab, I'd recommend a CHAMMA to JAMMA adapter, like the one JNX sells:
https://www.ebay.com/itm/155224211926
Shows OOS on ebay, but I think he is a member here and you could try to send a message and see if he has anymore available.
i been watching the thread too , to see if someone would have this issue lolIm curious, does this device have the same issue as the MGCD with flipping the XY and AB buttons? The Atlas I got from James had to be wired to swap the two. It basically made the Light and Medium punches and kicks swap places. With the Atlas this was fixed.
Sound comes through the 2 wires red and white directly probably to the board.It'd be interesting to hear some in-depth impressions from someone who has one. Or even a video demonstrating it. I'm also still unclear on how this thing delivers sound.
It should work perfectly fine on JAMMA cabs with a CHAMMA adapter or if you hack it up.
Yes, you need RGB and composite connected otherwise it wont work.Interesting... so how is it getting video? Using composite as sync or something?
I am not as familiar with the Dreamcast - so it looks like you can have the arcade control panel connected to the adapter itself and the peripherals, such as the fishing rod, can be directly connected to the 3rd or 4th controller ports of the console and used seamlessly with the cabinet/game? Obviously one would have to find a way to run them outside the cabinet, however, I wanted to clarify a steering wheel, light gun, or fishing rod could be used relatively easily in an arcade cabinet setup with this adapter as long as you can find a way to run them outside the cabinet while connected directly to the console - correct? Control the game via the arcade control panel and bring out the peripherals when needed? Seems like a nice option. Thanks.I just ordered a chamma adapter from the pcbjunkie etsy store. Will probably also make one myself later this week as shipping will take some time.
The converter works, just the controls are not because the pinout is not jamma.
Bassfishing works like a charm as the controller is not in the cab
So which button is mapped to which controller button? Because I'm hooking up my chamma->jamma adapter but still not the response I expedtee. Just trying to figure out which button on my cab should be wired to which controller button so I can rewire my cab a bit or the adapter
There was no pinout with this board so bit hard to guess.
