bravesirchris
Has anyone got a Sega Race Tv recovery disc, I've got a very dead hard drive and if I can get a copy of the recovery disc with out paying an arm & leg from Sega that would be a great help.
Hi,Export version disc is in Mame. Just Google 'dvp-0044.chd'. Use chdman.exe to convert into raw image and then burn with any decent burning software (like ImgBurn 2.5.0.0).
the dvd is not readable by win10 system, no i dont know about the usb dvd, its a basic sata2usb adapterWhat does the root of your burned ISO look like?
Are you sure your DVD drive is compatible with the Lindbergh?
yes the cf is booting every time until no destination disk, now that i changed it I get validate destination diskare you bootling into the cf-card with the dvd connected?
Thats what i did, I connected a usb to sata adaptor and an internal sata dvd. But now I'm not so sure about the data extraction from the chd file, because i cant see any data in the dvd. Maybe you could tell me the correct command line or point me to a "how to" ?You have to connect the drive to the USB ports. If you don't have an adapter for the mini USB ports, you can remove the mini USB block, there are standard sized ports behind it.
I will try some more dvd drives then, thank you very much.Ahh, I see. The SATA DVD drive is likely your issue.
There isn't anything special about the command.
extractraw -i dvp-0044.chd -o dvp-0044.iso
