waiwainl
Nice work!
Thanks for the info. I took some time to play it and can confirm the hack works.For what it's worth, Puyo Puyo 2's copy protection only does a few things. What you must watch for is if it disables the Sousai system (garbage), and if it halts at the end of the round, not showing the other character.
With my patch I have cleared the whole game many times without issues. I can try yours to clear it if you'd like, but if you are able to even beat one round successfully and the Sousai system works correctly, then you do not have anything more to worry about.
The game runs the check against the Altera device, but it also checksums that routine.
I wrote about some of them here: https://tcrf.net/Puyo_Puyo_Tsuu_(Arcade)
Borench, Columns and Columns II are System C games and can be swapped without any wire hackery.So can Borench be installed on a Columns PCB without any hackery? It's a tough game but I like it and wouldn't mind having it in my collection.
Just google them.do you have the default dip-switch settings for each game?
As when I swapped the roms etc from a faulty TFAC pcb to a working tanto-r I had to change the jumpers to get it work.
Dips I leave all off.Just google them.All I now is all games boot with all dipswitches set to off.do you have the default dip-switch settings for each game?
You're talking about two different things, dipswitches and jumpers.
Surely jumpers have to be moved between games due to different ROMs size.
The multi kit however requires the jumpers to be set for the biggest capacity (just like the multi CPS2).
Not sure for 256kb EPROMs but System C doesn't support 512kb EPROMs unless you do some wire hackery. That's one of the reasons the multi kit isn't compatible with System C motherboards (only System C2).Ok here's another dumb question: Does anyone know how to set the jumpers on a Columns board for larger EPROMs like a 27c2001, 27c020 or 27c2048?
Turns out of course the EPROMs used for Columns are smaller than those of Borench, and I can't seem to find info on this board's jumper settings anywhere.
Bloxeed is System C, Puyo Puyo 2 is System C2 so short answer is NO.can bloxeed be converted to puyo puyo 2?
is there a guide on how to make it support bigger roms? are the samples audio samples?Bloxeed is System C, Puyo Puyo 2 is System C2 so short answer is NO.can bloxeed be converted to puyo puyo 2?
Long answer is yes, IF:
1) you install the missing parts on your C board (sample part)
2) you do some wire hackery to support bigger ROMs
If you don't care about samples then only 2) is necessary.
